Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I changed the belt on the mower deck and the next day the belt was torn to shreds can any one help me....
    President:
  • 1,486 Answers
Drive pully bearings worn.Or a damaged pully.
Posted on Jul 04, 2009
Primary belt rubs on bracket n keeps shredding/// new replace ment deck...just purchesed
Look under the the left foot rest,there is a belt installation diagram. It will show how to install the belt correctly. It is real simple to replace belt,but the belt must be installed on the pulleys,correctly or it will fail,every time. Sincerely,Brad Locke
Jul 27, 2015 | Craftsman Garden
Shredding new belt on john deere x300 mulcking deck
Is the belt tight enough? Is it aligned to all the pulleys? Make sure these are ok and I am sure you will find the problem.
May 18, 2012 | Garden
My deck mower(craftsman 917.271530)keeps shredding deck belts
You either have a bad bearing on one of the pulleys or one is loose and moving up and down drawing the belt when it is engaged. I would pull the mower deck off and go through it .
Apr 17, 2012 | Sears Garden
How do you adjust the pulleys on a 42" 20 HP craftsman tractor mower. The belt burned off and when I replaced it with a new one the new one began to shred
There is no adjustment on these pulleys. Sounds like the belt was over the blade pulley brake arms or idler pulley guide. They will shred a belt in nothing flat.
Sep 17, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a swisher ride king mower that keeps shredding belt from moter to deck. dose anyone have solution?
I have been told if the parking brake is engaged and you try to drive the mower it will instantly put a burn spot on the belt. I hope this helps.
Aug 11, 2010 | Swisher Ride King Zero Turn Mower 23 Hp,...
42" deck belt shredding
One of your pulleys is frozen and the belt is just going around it without it turning. Pull the belt out, remember where it goes, and find the pulley that is frozen. Get it replaced. Hope this helps.
May 04, 2010 | Poulan Garden
Craftsman 19.5hp 42 drive belt shredded
most likely the belt was put on the wrong side of the belt retainer clips on one of the two pullys. I've done the same thing more than once. Make sure on next belt there are no sharp edges touching anywhere and while engaged or not.
Oct 22, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Shredding belts
first make sure the belt is not hitting anything when the blade is engaged (engine off), the if ok remove belt and look in pulley grooves for rocks or chips., then run finger all around groove to make sure there is no catches or spurs. If that is all ok then with belt on and engine idleing as slow as possible and blade engaged look and see if pulley is wobbling, BE CAREFULL !! look at the engine pulley first then with EXTREME CAUTION look under deck from opposte side of chute. ( Check with deck at highest setting)
Jul 24, 2009 | Mtd Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
165 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
