SOURCE: Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
SOURCE: My Daytona Watch: On the back
RECOMENDATION:
Contact a local official Rolex dealer to address the problem.
GOTO:
http://www.rolex.com
To find a local dealer.
Hope this tip helps.
R/
David
SOURCE: i have a' rolex oyster perpertau
i have a' rolex oyster perpertau superlativechronometerofically certified cosmograph' watch with an inscription on the back'winner rolex ad daytona 1992 24' is it a genuine rolex and if so what is it worth.thanks curtis and the date pointer came out from it place how to fix back?
SOURCE: want to know if my rolex is fake it states winner
Sorry to say it's a reproduciton..and not a very accurate one..
The three front dials should not reference any days hour dates etc..
There should be nothing engraved on the back
The "second hand" is a sweep timer hand on the original.. it should be stationary at the noon position unless activated.
Probably a good looking watch.. but it's not a Rolex.
Best of luck
