Question about Hoover F5906-900 Upright Steam Vacuum
My carpet cleaner won't turn on
I was using my Hoover Steamvac model F5906-900 a few days ago and the collection compartment lid came loose (quit sucking), so I turned it off to reattach it and when I went to turn it back on....nothing. It won't start, make any noise, NOTHING. HELP! I spent way too much money on this thing for it to stop working in less than a year!
  • 126 Answers
Re: My carpet cleaner won't turn on
If this machine is less that a year old, DON'T TOUCH IT! Take it in to a warrany depot and let them deal with it. Make sure that you take your proof of purchase with you and insist that they inform you of any Non-Warrany issues before repairing. Normally, these machines don't have any exlusions to the warranty, but the Hoover company is under new management and they may have different warranty coverage.
Posted on Jan 13, 2008
0 characters
3 Points
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
No suction of hoover carpet cleaner
Might be a bad blower/impellar - you must disassemble to check. But most likely the lid on the recovery tank is not installed correctly allowing air (suction) to leak. On most models you can remove the solution recovery tank, turn the unit on and feel for suction where the tank fits onto the base (look for the round, black rubber type seal in the front corner that mates to the round outlet on the underside of the recovery tank.) If there is good suction at this seal, then the problem is an air leak, almost always due to a loose or incorrectly fitted lid on the recovery tank. Also, if you have a detachable insert (for attachments) on the front of the recovery tank, check that the insert is installed properly. If this is reversed it will not provide suction.
Sep 02, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
Hi There,
I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
Here are step by step instructions for you:
Step 1. To prevent possible leaking, remove
clean solution tank by pressing down on
tank handle (D) and pulling forward; set
tank aside (do not set tank on furniture2_bing.gif).
Remove hose from storage rack.
Step 2: Step on handle release pedal (E) and
lower carpet cleaner handle until it rests
on the floor.
Unlatch back part of recovery tank and
remove lid.
Step 3: Remove recovery tank front panel (F)
by sliding it straight up.
Step 4. Replace panel with converter (G).
Slide converter halfway down opening
until it is firmly in place.
Step 5. Before connecting tube (H) to
cleaner, make sure black tabs are
extended by pulling tan collar toward
Open door on hood labeled “Stair/
upholstery Cleaning Connection”. Press
round solution tube connector onto
round projection inside door. Press connector
collar down firmly to ensure
that it is fully connected.
Step 6. The tank replaces in a hinge-like
manner. Position front of lid under tabs
(I) on front of tank. Rotate lid down onto
Make sure lid is secure on all sides
before cleaning.
For full suction, it is important that
the recovery tank lid is properly
secured before cleaning.
Reverse procedure to remove hose
and solution tube.
Raise carpet cleaner2_bing.gif handle to upright
I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
Thanks again,
Chris J.
Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Instructions on Using The Hoover Steamvac Ultra cleaner
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
Carpet and Upholstery Detergent
Instant Stain Remover
Carpet and Upholstery Spray
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Jul 11, 2009 | Hoover F5872-900 SteamVac Wet/Dry Vacuum
Hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Oct 06, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Catch tank empty
Which you had posted your model number, If you have a foam filter on the inside of tyhe recovery tank lid, make sure there is at least a 1/4 in. gap between the lid and the top of the filter. Make sure that the lid is locked down in the back, try to push it up, if it is locked it won't move. If yours has a place for a duct in front of the recovery tank, make sure it is there and pushed all of the way down.
Apr 02, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
make sure all parts are snapped in again i did the same thing.......
Mar 17, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac F5892-900 leaving lines on carpet, does not seem to spray
Is the cleaner sucking up the water like it should? If not , check that the filter on the inside of the lid has a 1/4 in. gap between the filter and the top of the lid. Either that or the water isn't completely being shut off when you release the trigger, in whcih case you would probably have to take it in for service.
Jan 31, 2008 | Hoover F5892-900 SteamVac Upright Vacuum
The automatic shut off
Check the filter on the inside of the lid for the dirty water tank. It needs to have a 1/4 in. gap from the top of the lid to the top of the filter.
Oct 13, 2007 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover F5906-900 Upright Steam Vacuum Logo
80 people viewed this question
Top Hoover Vacuums Experts
Roger Potts
Ryan S
Ryan S
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
