Question about Nintendo DS Lite Console
My nintendo ds lite microphone isn't working!
Well, it's a problem with a lot of people. My mic, for some reason, is not working. I speak into it, correctly, and it does not record in the ds and it's useless. I don't know why this happened. I'm checking everything, and I can't seem to find a problem! This happened one day when I finally charged it. After I charged it, the mic wasn't working. I charge it when needed, and the mic still doesn't work! HELP!
  • 56 Answers
Suspect the mic has gone faulty if it went all of a sudden.
Posted on Jul 04, 2009
5 Suggested Answers
SOURCE: nintendo ds lite microphone doesnt work
Doh. Wish I read this before I bought a headset. But if the mic does not work, the headset apparently doesnt help. If your under warranty, contact Nintendo. If not, I think we're out of luck unless you want to shell out $75
Posted on Jan 04, 2008
GameBoyFreak
  • 17 Answers
SOURCE: microphone not working
The microphone level can only be adjusted in certain games. Have you tried using the mic in any other games? Most likely, the mic is simply defective; I have heard of more than one case of manufacturing defects with Nintendo DS microphones. How long have you had the system? If it is still under warranty, Nintendo should fix the system for free.
Posted on Jan 28, 2008
  • 6 Answers
SOURCE: my Nintendo microphone
The seperate mic will not work if the mic in the DS is broken.
Posted on Feb 24, 2008
  • 78 Answers
SOURCE: DS Lite Console: my nintendo ds lite won't read game cards...
look inside the slot 1 slot, you probably have damaged pins. In this case you will need a new cartridge slot.
Posted on Aug 11, 2010
Is there a place for my mic to get fixed cheap???
if memory srves me right you can get a mic headset that plugs into the stereo headset jack thus solving the prob, google summit like or similar to mic headset for ds, it should help.
Mar 30, 2009 | Nintendo DS Lite
Ds lite microphone not working. help!!!!!!!!!!!!!
Hi, The Ds microphone is relatively straight forward to replace and can be bought on eBay etc if you wished to fix it yourself. Alternatively if you contact a local DS retailer they will be able to put you in contact with nintendo who will fix it for a fee.
I don't know of anyway to bypass the activities in any games reliant on the microphone.
Mar 30, 2009 | Nintendo DS Console
Blowing into microphone on Nintendo DS lite
There is no opther way at all. Most probably ur MIC isnt working any more. Thats pretty sad, if its under warranty, nintendo will get it replaced. If not, forget playing that game. sorry.
Mar 23, 2009 | Nintendo DS Lite Console
My nintendo ds lite microphone has stopped working
You are going to have to buy a mic headset.I reccomend that to everyone cause that happened to me.
Jan 23, 2009 | Nintendo DS Lite Console
Nintendogs experience microphone problem
Phillyxx1995
It is not the game that is here the problem. It is the DS Lite.
Your microphone is disabled by a defective connector at the front of your DS Lite.
I explain...
On the front left of youre DS Lite, there is a headset connection. Inside this connector (soldered on the mainboard of the DS Lite) there is a contact that shuts down the microphone on the top screen enclosure if this headset connector is used.
For some kind of reason (and I see a lot of them), this internal switch stay closed when a headset was inserted and removed again Result.....the microphone in the enclosure is always off.
I've even seen this problem without ever using a headset and the front connector.
The only way to solve your problem is to replace this headset connector by Nintendo or a DS Lite repair service
John
Oct 31, 2008 | Nintendo DS Lite Console
Microphone not working
Jan 27, 2008 | Nintendo DS Console
Mic not working
Try to speak away from the device until it starts to work.
Jan 04, 2008 | Nintendo DS Lite Console
My Nintendo microphone
My Nintendo ds lite also would not respond to voices. I have brain age 2 and Zelda. In the Zelda options there is a mic test. This will show a graph bar that measures your voice. Well the mic was not working at all for either game. I simply took out the battery and held the power slide for a couple seconds. Amazingly the mic works now for both games. I do not know if moving the power slide is significant, but on computers to de-static them you remove all power sources(battery and ac adapter) and hold the power button for 10 seconds.
Oct 30, 2007 | Nintendo DS Console
Nintendo ds lite microphone doesnt work
I fixed the MIC on my DS LITE very easily, after first replacing the MIC with a new one and finding that it still did not work (not an easy thing to replace either)! The internal MIC signal is routed to a contact at the front edge of the DS, which allows the internal MIC to be disconnected when an external MIC is connected. If this contact (which is normally held closed by the springy nature of the contact) gets dirty, then it effectively goes open circuit, disconnecting the internal MIC signal. You can use a cotton bud and a little WD-40 (contact cleaner) to clean the contact (clean the two pins next to the 3.5mm jack connector) to restore the electrical contact. Takes 5 minutes and is a LOT easier and cheaper than replacing the MIC or paying someone to repair it!
Oct 30, 2007 | Nintendo DS Lite Console
adjust the proximity of microphone or call nintendo helpline 08706060247 which has a 24 month warranty
Oct 24, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
312 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
