Question about Frigidaire FDB1050REM Dishwasher
Dishwasher water pump problem
Water does not pump into dishwasher after it has been disconected and reinstalled.
  • 224 Answers
Make sure the angle stop is open (the valve that comes out of the wall and is connected to the pipe that goes into the wall). This is what allows water to be supplied into the dishwasher basin.
Posted on Jul 04, 2009
What is the correct water level in a kitchenaid dishwasher?
There is a float inside, the float should be nearly to the shut off position when the dishwasher is full. If it isn't add water until it's about 2 inches deep, or within 1/2 inch of overlowing the front of the dishwasher. Run a cycle and see if your dishes are cleaner. If so, then the likely problem is with the water pump. Take this off, clean all screens and soak in Lime-Away or something similar and reinstall. In all probabilty if the dishwasher doesn't fill, there is dirt in the pump screen or buildup in the pump itself. If this does not fix the water level, then a new pump may be necessary (around $20-$40 on eBay).
Apr 15, 2012 | KitchenAid Dishwashers
The top drawer will not take in water. The tap symbol flashes. The bottom drawer is working perfectly. I have cleaned and checked it - no obvious obstruction in the drawer.
1 the inlet valve need replacing its bottom of the draw bit tricky to replace it to check it just unclip bottom draw to the side disconect the hose from the inlet top draw valve and turn it on for a sec see if water pumps out make sure you got small bucket if that works finne. 2 its the pump under neath the dish draw thats very tricky took me 1 hour to do
Sep 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water remains in the bottom of the dishwasher (18 months old). Disposal is clear, glass trap is clear. What should I look for?
First : if this started after a new disposal was installed then you need to check the Knock out on the disposal located inside the pipe that sticks out of the disposal where you conect your dishwasher drain hose. ((((( Common Problem )))))
Ok, moving on, your dishwasher has a independent drain pump. if you know the noise of the drain pump and you do not here it. its a good chance that its bad and you can disconect it and put a volt metert to the 2 wires and check for 110V. of coures after you have your volt meter in place and ready to go you will then put your diswasher in drain and check your meter.
Here is a breakdown of a dishwasher with a simialr model number. # 60 is the drain pump.
Jan 09, 2010 | Frigidaire PLD4555RFC Dishwasher
THE UPPER TRY DOES NOT GET CLEAN, THE SPRAY ARM ON THE BOTTOM OF THE UPPER TRY AND THE SPRAYER AT THE TOP DO NOT TURN?THE WATER THAT COME SOUT AT THE BOTTOM IS WEAK ? WHY?
It could be that your dishwasher is not getting enough water. Let the water fill the dishwasher, set the spray arms in the same direction. Add a large pot of hot water and run the dishwasher. Open the door and check to see if the spray arms have moved. If they have moved, replace the water inlet valve.
Remove the 4 screws holding the lower kick panel. Remove kick panel. Locate the water inlet valve. This is the electrical valve where the water pipe hooks into the dishwasher. Shut off the water to the Dishwasher and electrical to the dishwasher. Disconect the 2 wire plug at the water inlet valve. Disconect the water supply to the dishwasher at the valve and disconect the rubber hose attached to the valve. Install new valve and test machine.
I hope this helps.
Jan 05, 2010 | Dishwashers
My GE Profile Dishwasher circa mid 1990s will not completely drain. I took the drain cage off and found pieces of broken glass and old food remnants in it. I used a shop vac to **** it all out....
Sounds like there is. It is common to find objects or small pieces of cloth stuck in the water pump. Remove the water pump and disassemble it and reinstall it. Or purchase a new water pump and replace the old pump.
Oct 22, 2009 | GE 24 in. Profile PDW7800 Built-in...
The water doesn't seem to drain in my Kenmore Elite dishwasher. Could this be a pump issue?
No , this is usually due to corn or rice that has plugged up in the diaphragm within the drain line that connects to the pump. Disconnect the line from the pump and remove the hard pipe from the pump. Clear debris and reinstall. Should use a shop vac to remove the water within the dishwasher or you will have a mess to clean up.
Jul 24, 2009 | Dishwashers
Water will not drain out completely
You probably have a partial blockage in the drain line or the drain pump. This is not difficult to check. Just open up the panel below the door of the dishwasher and look for the flexible drain line. It is attached to the drain line pump. Unscrew the pump from the dishwasher frame, disconect the drain line and take a look at the pump and the drain hose. You may find a piece of glass or other hard object that is causing the problem. good luck.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher gets no water
It is no fuse in dishwasher.
Solution1: Check if the inlet line to d/w is open(usually it located under the sink)
Solution2: To rich a fill valve filter:
1. Shut off water to d/w
2.open kick panel under front door of d/w
3.disconect the water line on left hand side
4.pull filter from center of water valve by nose pliers
5. clean the filter by old toothbrush under the sink
6.put everything back
7. if does not help the water valve needs to be replace
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Nov 29, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
GE dishwasher
I just fixed this problem. Cause, a bone in the drain pump fins. Soloution: Get as much water out of the unit as possible, get a bunch of towels.Turn off water and dicconect all lines including the electrical. Pull unit out from under the counter and turn on right side (GE model that I have), mop up water off floor. Find the drain line and disconect from pump. Get your Torx set out and remove the 3 screws holding the housing and gently lift the pump motor. Remove the clog/blockage and replace the motor being CAREFUL to get it in straight so that youy don't screw up the big O ring. Replace all the screws etc. Hook up all the lines as you re-insert the unit back under the counter. This woked for me but as you can tell I had no "broken" parts.
Dec 16, 2007 | Dishwashers
Dishwashers Logo
130 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
