Question about Boating
The carburetor bowls on my 1989 evinrude 70 hp were full of oil. what could cause this ? Walt
    Champion:
  • 207 Answers
The vro or oil injection is bad those old omc engines are notorious for that happening when the sit for a few weeks or a few months you can order a new unit but there not cheap and it will just happen again best thing to do is disconnect the unit and mix oil and gas 50;1
Posted on Jul 05, 2009
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Jun 09, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
How do you change the gear lube in a Evinrude Triumph 70 hp outboard motor?
Hi .
There should be two flat screws on the lower leg, remove the bottom one and then the top.have the motor fully down position to drain, when filling with new oil it has to be done from bottom to purge the air out, Gear box is full when foil comes out top screw, install top screw and then bottom, you'll lose a bit of oil when bottom is removed install . if not sure have a look on YouTube, it should help you out.
Good luck.
May 28, 2016 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
1989 Yamaha Razz stalls when throttle applied
Hi, Dstelte and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Razz wont staY RUNNING Scooter Invasion
Razz 88 Bogs up hills and full throttle
Yamaha SH50 Razz 50 Scooter Workshop Service Manual 1987 2001 Download... $10
OEM parts for Yamaha
Yamaha RAZZ SH50L Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 27, 2011 | Yamaha Motorcycles
How to access carburetor for applying fogging oil in 1989 140 hp evinrude outboard?
The fogging oil does not go in the carb. It goes in the cylinders. You have to remove the spark plugs and spray the fogging oil into the cylinders. Turn the motor over a few times with the plugs out , respray and then replace the plugs. You are protecting the cylinder walls by doing this. hope this helps you. Jeepfxr
Nov 08, 2009 | Boating
Oil weight to use for 1989 evinrude 2 stroke 90 hp outboard motor
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
Sep 29, 2009 | Boating
Boating Logo
1,227 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
