My 2004 Honda shadow vt600 vlx quits running after approximately 10 minutes of riding. It just shuts off and won't start. Has a new battery, plugs and changed oil & filter. What will fix this problem?
SOURCE: where is the battery on a 2004 honda shadow vt600?
It is located underneath the seat.
You remove the right hand plastic cover under the seat and you will see another cover which holds relays and stuff.If you remove that too you will see the battery.
Check here for details
SOURCE: 1993 honda shadow, sometimes off the start it will
use a thin piece of wire and clean the ilde port and transfer port if that doesn't clear it up check idle jet
SOURCE: motorcycle dies while riding,like gas is cut off
Check fuel pump. You might have a bad diaphragm.
SOURCE: How do i install a HONDA SHADOW VLX VT 600 VT600
Clamps rite on frame at radiator.mounting hardware should come with bar.put rubber patch on frame to protect custom frame paint.
SOURCE: how do i install saddlebags on a 2007 honda shadow
I've got a 2007 Shadow and recently put on a set of saddlebags. What you do is use a large allen wrench or star wrench on the seat strap to take out those two bolts, and then you slide the seat towards the back of the bike (or perhaps you need to slide it to the front, I forget, its just the "picture-hanging" connection, <=0 is the shape of the hole on the seat, and on the bike beneath it is a peg, with the seat hole large enough to slide the peg through, but once you shift the seat to its natural position the head of the peg is at a place too narrow to come off, hence the sliding motion to remove it) . Then it is smooth sailing, just lay your saddlebags over the peg with the seat removed, and try and put the seat back without disrupting the bags too much, which can be hard since its a pretty snug fit. Hopefully that helped, I don't know if the request was talking about post market support frames or something
