Question about Car APS787A Remote Start and Security System with Keyless Entry
Audiovox aps787a will not activate starter - Car APS787A Remote Start and Security System with Keyless Entry
    Sniper:
  • 50 Answers
Do you have the hood pin hooked up ? If so is it closed? Is the neutral safety switch grounded ? Usually it something over looked, so simple it seems unimportant. Thats where I would start. After that try learning the tach. What kind of car by the way, does it take a bypass?
Posted on Jul 05, 2009
Where are the black and red wires connected from the prestige aps787c remote car starter two wire yellow plug 2 pin transponder control output? i will also be using the dbal2 bypass module. thanks
The only 2 pin connector is for the transponder bypass module.
These wires are for the following outputs
2 Pin Transponder Output Harness #1123292
1) Red Battery (+) 100mA
2) Black (-) Output While Running 100mA
This connects your transponder key module to the starter, it activates the module when cranking to simulate a key.
a: When selected for while remote start on, the Black wire will be active at the same time ign. 3 becomes
active, and will remain active all the time the unit is operational under the control of the remote start.
b: When selected for output during the start sequence, the Black wire will be active at the same time Ign.
3 becomes active, and will remain active until the vehicle has started. This will be used for one time read
transponder circuits.
c: When the unit is selected for until ignition off, the Black wire will become active at the same time ign.
3 becomes active and will remain active even after the key take over and until the ignition in the vehicle is
turned off. This will allow the unit to be used for continuous read transponders circuits
Nov 14, 2014 | Prestige Remote Start
2002 grand am remote starter
The most likely cause is one or more of the safety features are engaged during the attempt to remote start. The lights should flash a sequence that corresponds to the reason for failure to start. Your owners manual will describe what the sequence means. Based from experience, I suspect that the hood pinswitch has malfunctioned or damaged so the system thinks the hood is opened thus preventing starting.
Nov 13, 2011 | Prestige Remote Start
I'm looking to get the user manual for a car alarm: aps2k4sflcf.
Go to this site http://auto.manualsonline.com/manuals/mfg/audiovox/audiovox_remote_starter_product_list.html
and click on Platinum APS 686T - Audiovox Remote Car Starter Owner's Manual
and click on APS 686 - Audiovox 4 Channel Remote Car Starter Owner's Manual
Jan 16, 2011 | Prestige APS686T Remote Start and Keyless...
I have a carlink app on my sprint evo to start my car using the automatic starter. it's asking for a SIM id & passcode (4 digits). I don't know what that is or where to get it. Can someone please...
You have to purchase the Link Module from your local alarm dealer and have them install it onto your existing audiovox alarm unit. The Link Module will come with it's own SIM ID and the 4 digit PASSCODE will be provided to you by the dealer for activations. You can't just download the app and expect the app to know what type of car or where your car is located in the US to remotely start it.
Nov 10, 2010 | Audiovox Prestige Cl100 Carlink System
I have the audiovox car aps787a remoe start and scurity when you open then hood the remote start starts
CHECK DARK BLUE WITH BLACK STRIP WIRE COMING OFF BRAIN AND CUT IT. THIS WIRE WILL CAUSE IT TO START. IT WAS IMPROPERLY WIRED AND HOOKED INTO THE PIN SWITCH INSTALLED IN ENGINE. YOU CAN CUT THIS WIRE ALSO AND TAPE IT OFF COMING OFF THE PIN SWITCH IN ENGINE.
Nov 01, 2009 | Car APS787A Remote Start and Security...
Reconnect remote starter
Those devices, when operating properly, are commonly not disconnected, but you could attempt to find the power lead and the in-line fuse to make those re-connections, also check the battery(s) in the remote. If the disconnection is more in-depth then you should acquire the installation and owners manual from Audiovox, so as to troubleshoot and maybe discover what else is disconnected.
Good luck...
Feb 23, 2009 | Car APS921 Remote Starter - Keyless Entry
Prestige platinum by audiovox need to replace the remote for it
if you need a remote you can buy one from audiovox.com and also you can download the installation manual and user manual in which that will tell you how to program the new remote for the remote start.
Feb 15, 2009 | Prestige 2 Button Remote Security System...
I am installing a Audiovox Car APS787A start keyless and alarm in a 96 taurus and i was wondering if there is any adapters or special tools needed
you might need a ford pats key bypass module for this. The way to tell is if your key is a thin black butted key or has a thick black casing on the end of it. if it has the thick casing then you will need one.
Jan 29, 2009 | Car APS787A Remote Start and Security...
Audiovox car alrm
what model is the audiovox alarm system? If the alarm is not remote start ready, then you will need to install another alarm system or a stand-alone remote start system.
Sep 11, 2008 | Audiovox Car Audio & Video
Car APS787A Remote Start and Security System with Keyless Entry Logo
175 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
