Home | GE | WBSR3140DW Top Load Washer | If you can hear the was...
GE WBSR3140DW Top Load Washer
Problem for GE WBSR3140DW Top Load Washer
If you can hear the washer move into the cycle
By jkcokley on Jul 04, 2009
If you can hear the washer move into the cycle where it drains and all other cycles work (ie spin, wash ect). Then you either have a faulty pump or a clog. A pump change is a relatively easy fix.
How do you actually go about fixing this!!!!!
Solution #1
posted on Jul 04, 2009
Not Rated)
pmcdermott02
Rank: Apprentice
Rating: 88%, 4 votes
Remove the front panel. There is a short hose that goes from the tub to the pump. Sometimes you can remove the clog by gently squeezing the tube with the machine on and it will clear. The other option is to get all the water out of it then remove the tube to clear it out.
Was this helpful?
Yes
No
Popular Solutions for GE WBSR3140DW Top Load Washer
Questions and Unsolved Problems for GE WBSR3140DW Top Load Washer
Do you recommend GE WBSR3140DW Top Load Washer?
Answer
Answer
hoover 5k top loader agitator doesnt move ,water goes in ,power ok the cycle goes through ok ,the... (More)
Answer
GE Select washer 0n spin cycle is not spinning all the water out of the clothes even on the extended... (More)
Answer
Tub does not fully spin on normal wash, also, tub and basket tend to rub.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE WBSR3140DW Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14187
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
