Question about Garmin StreetPilot 2610 GPS Receiver
Garmin 2610 left side of screen inop and remote
    Brigadier General:
  • 4,090 Answers
T6ry recalibation of the screen
Posted on Jul 06, 2009
Garmin streetpilot 2610 does not turns on!!
There is no battery on Garmin Streetpilot 2610 so you have to plug it in !!!!
Feb 10, 2013 | Garmin StreetPilot 2610 GPS Receiver
I cannot program anything into directions because the screen does not bring up the number or letter when you touch it, it brings up the letter/number to the left of it. You cannot get the numbers/letters...
The problem is the screen needs to be calibrated, however this sometimes doesn't work if the touch screen is failing. I saw a lengthy procedure posted here in a different solution I have yet to try. But for the calibration you will go to menu - > display -> press FIND and follow the directions on screen. If calibration fails repeat, or find the other lengthy instructions here and try those. Several people claim they have worked, again, I haven't tried them. Another option is to purchase a remote for the unit. I have one and use it for mine because my screen totally failed. I have since replaced the screen with a junk unit I purchased on EBay but prefer the remote over the touch screen for most things. Remotes are about $30 bucks. If you're lucky you might be able to find a 2610 that includes a remote for around $50 and pick up an extra set of accessories. Good luck and post back if you have any other questions.
Mar 18, 2010 | Garmin StreetPilot 2620 GPS Receiver
Unknown symbol top left hand side of screen
It Denotes, "Call Forwarding Feature is Activated"...
Oct 31, 2009 | Nokia 2610 Cellular Phone
The remote on my Garmin Streetpilot 2610 not all
You can take it apart and clean the visible terminals.
Sep 16, 2009 | Garmin StreetPilot 2610 GPS Receiver
Touch screen letters inop on right side. Also when I try to scroll on left side it selects a street instead.
try to calabrate the touch screen if it dosnt work replace the touch screen part# CSX1085
Jul 22, 2009 | Pioneer AVIC-D2 DVD Nav/6.5"...
2720 street pilot replacement
The screens are not interchangeable. The 2610 screen is 3.3x1.7" and is 305x160 resolution. The 2720 is the exact same size but 454x240 resolution.
Jan 13, 2008 | Garmin 010-00358-00 GPS Receiver
My GPS system is having seizures
The solution is listed on the garmin site but it is not clear
The problem is with the infra red remote reciever on the unit
Sometimes the sun acts like the remote is being pressed and that is when it shakes
the solution, and I hope you still have the unit cause there is nothing outthere like it.
Answer: from garmin site Normally this issue is caused by sunlight from certain angles hitting the Infrared (IR) port on the unit. This makes the unit react as if the remote control was communicating with it. This makes it switch in between screens just like if you were using the remote.
You can disable the remote IR port on your StreetPilot® 26xx unit by:
  1. Powering your unit ON
  2. Press the Menu button
  3. Touch Options
  4. Touch the General tab
  5. Press the Menu button
  6. Touch Disable remote
If you wish to use the remote again you can enable the remote IR port on your StreetPilot 26xx unit by:
  3. Touch Options
  6. Touch Enable remote
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=2610+remote+off
Dec 26, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin 2610 'ok' doesn't work
Try brush around the edges of screen...press the edges and work out dirt.... Let us know. See other posts...Same problem with screen touch system not responding.
Nov 10, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin 2610 freezes-up
CHECK THIS OUT IF SCREEN CLEANING DOESN'T WORK.
Regarding the screen jitter, believe it or not, the infrared port is causing the issue. If you disable it through settings inside the unit your issues will go away. The sun basically destroys the infrared sensor and the unit "thinks" a button on the remote is getting clicked continuously.
Nov 03, 2007 | Garmin StreetPilot 2610 GPS Receiver
Touchscreen problem
your screen needs to be recalibrated Press the "Menu" key Select Display When the "Automatice Brightnesss comes on the screen Press the "Find" Key, follow the instructions you will have to touch the dot that comes on the screen about four times and then you will be able to touch all keys when completed
Aug 22, 2007 | Garmin StreetPilot 2610 GPS Receiver
Garmin StreetPilot 2610 GPS Receiver Logo
290 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
