Question about Frigidaire Affinity ATF7000E Front Load Washer
How do i get to the pump?
And then when i find it, how do i unclog it? (hubby in afghanistan) do i need to call a repairman?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 120 Answers
Normally there is a front lower panel that can be removed. If there isn't you will need to remove the back panel. After removing the panel you will be able to foind the pump. Make sure before you remove the hoses on the pump you get a pan to catch the water from the washer. If you don;t do this water will go everywhere.
Posted on Jul 04, 2009
Where is the drain plug?
sorry we can not see it thru the computer screen either . perhaps a repairman will see it .
Sep 12, 2015 | Refrigerators
Tip
Panasonis Workio DP-4530 service manual?
Hello
My name is Edo and I am IT for UN mission in Afghanistan. We have copier Panasonic Workio DP-4530 and it is heart of our design office. We use copier for publishing documentation, for copying and printing. We can find any normal service in Afghanistan. The nearest place for repairing is Dubai.
I have experience with copiers and I want try to fix our copier. Currently, our new problem is error “clean fusser web”.
I need only if anybody have service manual in pdf or similar format. I will be very appreciated if anybody can help us. Your any advice is welcome as well.
Mr. Edin Husejnefendic
IT Systems Manager
Vertical Structures Unit
Afghanistan Operations Center (AGOC)
United Nations Office for Project Services (UNOPS)
House No. 6, Behind Emergency Hospital
District 10, Shar-e-Naw
Kabul, Afghanistan
Mobile: +93 0799 303-021
http://www.unops.org
on Jan 06, 2008 | Panasonic Workio DP-4530 Copier
We need to know where the main drain is located on our unit or how to access it so it can be opened and cleaned. It stopped up and the secondary overflow line running to the outside of the eve worked...
Unfortunately, if you're elderly and sick, you'll need to get the serviceman back to unclog it for you. As it will require crawling on your hands and knees, to access the main drain and then running an auger or high pressure air into the main drain line to unclog it. Not something, under the circumstances, I think you would want to undertake.
Sorry you're having the problem.
Apr 21, 2011 | Heating & Cooling
How do i unglog a pump? and where is it located?
Do you have an air compressor on hand? If you do , you can connect an air gun to the water line from the spicket and set the machine to fill and blow the air through intermittantly. That may unclog it. If you can't do that I would call a repairman. Well, I would fix it, but if I were you.
Jul 04, 2009 | Frigidaire Affinity ATF7000E Front Load...
Question
ipod touch doesn't have a phone on it, the mp3 player will work all over the world, might need a adapter for charger but noting else.
So yes it should work just fine.
Let me know if you need anything else.
Thank you,
Ekse
Jun 23, 2008 | Apple iPod touch
Unlisted error code on MAH-24 Maytag front-loading washer
Did you connect the wires back to the pump. The neutral runs through the pump winding and to the door interlock. Check the connections on the drain pump and the harness in general. Sounds like a broken connection somewhere.
Nov 05, 2007 | Maytag MAH2400A Front Load Washer
HOW DO I GET TO THE PUMP TO UNCLOG IT
siphon to drain the water then flip the washer sideway and locate the motor cuopling or broken belt and change this to a new one
Jan 07, 2007 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
155 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
