Question about Cameras
I can't remove the word ERROR from my camera. What do I need to do to make my carera functional again. This is for my DSC-3000.
  • Cameras Master
  • 2,200 Answers
Hi
Can you be a bit more specific as to when the error occurred e.g was it after you connected to a PC? What were the symptoms prior to the error?
Thanks
Posted on Jul 04, 2009
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
My cam sony dsc-h10 shows E:61:00 error
I had the same E:61:00 error and after a lot of browsing, i just did the unusual way.. slightly banged the outer portion of the lens twice lightly and it works again!
Oct 06, 2010 | Sony Cyber-shot DSC-H10 Digital Camera
How to take picture for digitrex dsc 3000 to my pc
To transfer your photo from your camera to the computer you have two options:
1. Use the patch cord (that came with the camera). Make sure camera is powered on to view photos. Click on my computer and the drive (removable devise) on the computer to view the photos.
2. Transfer the memory card from the camera to the computer.
Jul 21, 2010 | Apex Digital Digitrex DSC-3000 Digital...
Error:91:01 how do you get rid of it?
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
May 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
My camera is showing e91 error and no flash
It is the falsh module that has broken and needs replacing. (probably not worth it on a W50 due to cost.
but try the following.
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash.
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
Feb 03, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
My camera is saying card error
Reformat the card and see if that helps
Apr 01, 2009 | Casio Exilim EX-Z77 Digital Camera
Sony cyber-shot DSC-W100
I had same problem and found out after leaving the battery out for an extended time (4 hours) it totally reset and worked. The initialize function on the camera did not work.
Dec 08, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Error E91:01 on DSC H7
I had this same problem. Go to Home / settings / main settings / initialize. This resets the camera and you will need to reset the date-time.
Mar 12, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
E:91:01
easily just reset the camera with a pencil.
Aug 14, 2007 | Sony Cyber-shot DSC-T10 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
