FixYa.com
Tags:
ASUS VENTO 3600 PC Case - Red
Asus vento 3600
posted by kalen824 on Nov 10, 2007
I need to now how to take the plastic panels off of the metal, specifically the top one
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 22, 2008
Not Rated (0)
ahamed100
Rank:Wiz Wiz
Rating: 78%, 88 votes
Installation and assembly Now it was time to get to grips with the Asus Vento 3600 for real. We fished out a test motherboard and some drives and got to work installing the components into the ASUS case.
The side panel ships secured by a single screw which needs to be removed before you can use the side swivel handle to open the case. Once this was removed, turning the handle clockwise unlatches the side panel, allowing it to be pulled away. The swivel handle operates very smoothly and neatly, and adds immeasurably to the whole space-age feel of the case. The spacious interior allows plenty of room for all ATX motherboards. Thanks to the extra height of the case, the top two 5.25 inch external drive bays are above the plane of the motherboard, so even if you have a full size board, you can mount at least two CD drives without worrying about them interfering with the board.
The backplane of the case sports built-in risers for most ATX motherboards, though additional risers are included if your board needs more or different connections. Installing the motherboard was straightforward as we'd expected
One thing we noticed and appreciated at this point was the way that ASUS had rounded most of the steel edges inside the case. Having worked in computer stores, I appreciate any attempt to protect our tender hands from the pain of sharp steel 'case cuts'.
The expansion slot covers are secured by green plastic locking tabs which need to be levered open and removed from the case. The metal covers can then be easily removed and PCI, AGP or PCI Express cards installed. The tabs can then be returned to their places, locking the expansion cards in place.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Cases problems?
PC Cases
cobra and midland cb
i have a cobra 23 plus cb and a... Answer This...
PC Cases
installing mobo
I have an EVGA nForce 650i... Answer This...
PC Cases
case 990 three point hitch
I have a case 990 and the three... Answer This...
PC Cases
having the problem with...
iam facing the big trouble with... Answer This...
PC Cases
homesite of bestbuy.com
On bestbuy.com when i go to... Answer This...
Repair Service
Find PC Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
