Question about Honda Pressure Washer PSI 3000
Water pressure won't release in handle - Honda Pressure Washer PSI 3000
  • hal8104 Jul 04, 2009
    While pressure washing I stopped and replaced the wand with an extension pole and different tip. The tip was difficult to get on possibly due to the quick connect balls not detenting. After turning back on the pressure washer, I squeezed the handle and nothing came out the tip and the remained from the unit through the hose to the tip. All fittings are extremely tight and concerned about trying to break a seal and remove the tip under pressure.
    I suspect that maybe the tip is clogged. Is there away to relieve the pressure in order to remove the tip, wand or hose? Or do I have to be patient and wait overnight for reduced pressure on the fittings?
    Thank you,
    Hal
  • firehead May 11, 2010
    Can you clarify this. Does it squirt at all or does the trigger never open? Be verbose.
  • 32 Answers
You can try and loosen a fitting on the outlet side of the machine.
the machine will only hold the pressure for 15 -30 mins before the pressure drops.
Posted on Jul 04, 2009
  • 174 Answers
Unfortunately this is a problem. IT CAN BE DANGEROUS. Don't mess with the pump. If you unscrew anything on the pump it could fly off at a speed sufficient to injure or kill someone. Taking the inlet hose off may help. Waiting and getting a friend to assist is most adviseable. Please BE CAREFUL
My pressure washer starts if handle is pulled releasing water but when handle is disengaged no longer spraying water the motor shuts off, what could cause this on my new unit.
you have a faulty unloader valve have it inspected for possible obstruction in check valve which is normally located where you connect the high pressure hose.
Aug 17, 2014 | Garden
Drivers seat won't latch
Will it latch if you push the release handle down, you know opposite of trying to get it to release? It might be a broken or dislodged retaining spring that pulls downward pressure on the release handle. If this is not the problem then the teeth on the gear that the release handle engage are possibly worn out.
Apr 22, 2013 | 1999 Toyota Camry Solara
Water leaking from handle area (stops when you turn the shower on). How do I get the handle off to get to the cartridge?
Moen model L2175 has a set screw located under the handle or bottom side of handle that you must remove to gain access to cartridge....... Be sure water is turned off and you release water pressure before removing cartridge....... After removing handle there are a few more parts that will need to be removed(scald guard app.) may want to take notice which order you remove these so you want get parts mixed-u p. May-be this link will help you , it is an exploded view of parts and how they are can be removed
http://moenparts.faucetdirect.com/mediabase/specifications/ins162e.pdfp
Sep 05, 2011 | Moen L3175 Legend One Handle Shower Faucet...
I cannot get my washer to release so i can open it up and switch clothes over.. It has finished its cycle i even made it do another cycle to try and get it to release but it wont.. any suggestions? Kat
There are many reasons why the door may be jammed shut -
1. The water hasn't pumped out properly and the washing machine has a pneumatic door safety lock (a rubber hose connected to the door interlock and connected to a pressure chamber bottle on the tub - water forces air up this tube and locks the door)
2. Washing machine won't empty water
3. The water has pumped out properly, but a blockage of gunge inside the pressure chamber bottle is trapping the air that's operating the door lock (if a pneumatic lock is fitted - not many have these days due to cost cutting)
4. Door interlock jammed
5. Door catch, handle, or mechanism broken
Try running Just the rinse spin cycle again,
Jul 05, 2011 | Washing Machines
All hooked up dobble cked but water only trickles so ample supply
Make sure the hot water is turned back on. Pressure balancing valves won't work if both cold and hot water is not on. Pull shower head off and test to see how it flows out of the shower arm. If good, clear out shower head. Whenever water is turned off for a time, and then turned back on, restricting shower heads and aerators usually get clogged. In the future, always open up a tub spout before turning water back on. This releases the air and other debris most effectively before testing other fixtures in the house.
Apr 23, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    I have the Coleman powermate 2400 PSI pressure washer and on initial start it sprays and has great pressure. But once I release the spray handle it will not spray again, not even one drop of water. I have...
    Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
    I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
    Oct 22, 2009 | Coleman Garden
    Washer stops when handle released
    unloader valve not functioning properly causes pressure overload and stalls engine
    Sep 02, 2009 | Garden
    Will not release pressure and dies
    Your unloader valve is not functioning. Take it apart and make sure it all the parts are able to move freely under the spring. You may need a new o-ring or two if you see damaged ones.
    Aug 02, 2009 | Cam Spray 25006HT 2500 PSI Cold Water Gas...
    Water pressure starts off strong out of hose then fizzles
    Sounds like a piston seal in the pump may be bad. If there's any water leaking out of the pump, that's what it is.
    Mar 29, 2009 | Garden
    Honda Pressure Washer PSI 3000 Logo
    93 people viewed this question
    Top Honda Garden Experts
    John Trevino
    JOHN LAPIER
    Are you a Honda Garden Expert? Answer questions, earn points and help others
