Question about Frigidaire Affinity ATF7000E Front Load Washer
How do i unglog a pump? and where is it located?
Husband is deployed and i want to know if i can fix it myself or if i need to call a repairman........thanks
  • 40 Answers
Do you have an air compressor on hand? If you do , you can connect an air gun to the water line from the spicket and set the machine to fill and blow the air through intermittantly. That may unclog it. If you can't do that I would call a repairman. Well, I would fix it, but if I were you.
Posted on Jul 04, 2009
I've indicated already that it's NOT a brake, transmission, or timing problem. My husband and son have fixed EVERYTHING possible on it and still can't get it to start.
yes once a air bag is deployed most cars will not start. brakes will never cause a car to not start and the same with thew transmission. there is a air bag control module and it is located under the center consel
Nov 25, 2012 | 1992 Honda Accord
1996 Nissan Maxima DR window won't roll up swtich not working
see the diagram and think with clearly and logically NOT feared .God bless you.
test the wires connector, for loose, corrosion, and tight, test the switch for defective, motor, mechanism lube. etc.
Jul 25, 2012 | 1996 Nissan Maxima
We bought this mower about a month ago. My husband is getting ready to deploy for a year, so I thought I would mow today...to make sure I don't have any issues before he leaves. Of course, I...
The most simple solution is try using fresh gas (dump the old, put in new), if that doesn't work it is probably a carb issue that needs to fixed.
If for some reason you can't get it to work, one of the awesome non-profits available to military families is Project Evergreen, they'll mow your lawn for free while your husband is deployed. http://projectevergreen.com/
Aug 29, 2011 | Poulan Pro " Pro" Self Propelled Mower
My GE washer # WJSR2080T2WW (about 10? years old) won't drain but will agitate. I don't know if it will spin. Do I even bother to pay for a repair person to look at it?
This is more than likely a clogged or bad water pump. Most of the time it is just clogged. Check to see if the pump is clogged and if so unglog it and it should go back to work. If it is not clogged you need to see if it have power when the washer is in spin. If it has power but will not pump replace the pump. http://www.appliance-repair-it.com/clothes-washer-repair.html#GE
Oct 01, 2010 | Washing Machines
My washer goes through all the cycles and then once it is done and I open the lid,all the water is still in it. I have tried running the spin cycle a couple of times and it spins but still does not drain...
Use the video referenced below to disassemble the washer. Remove the drain pump from the front of the motor and clear out the sock or whatever is stuck in it.
You should use a shop vac or whatever you have to remove the water from the tub first.
http://appliancejunk.com/forums/index.php?topic=5191.0
Feb 08, 2010 | Estate ETW4400VQ Top Load Washer
Have there been any unexplained air bag deployment in 2005 santa fe on the drivers side while in motion. my husband was driving and he said the air bag deployed and then he hit a car in front of him. do...
http://www.nhtsa.dot.gov/cars/problems/ is the website I checked for your car and found no reference to this issue. There are reports of airbag deployments with no collisions, although they are rare. The computer in your car is capable of displaying the deployment, and may show which sensor in the front if any caused it to deploy (collision first/deployment second) or if no sensor signal (deployment first / collision second) is logged. Whatever the outcome, you will need a specialist in data extraction to achieve this.
Jan 06, 2010 | 2005 Hyundai Santa Fe
95 astro van will turn over but won't start. The fuel filter was replaced and when you turn the ignition key you can hear the fuel pump running and it'll try to fire once but after that it just will keep...
try changing the turn and brake light fuses.
this is a common problem i've run into and it usually solves it.chevy for some reason hooked the fuel pump in with this fuse.
good luck
Jul 20, 2009 | 1995 Chevrolet Astro
Front Brake is Locked
Now that you have bled the brakes and everything seems okay, try pumping the brake lever many times while the bike is stationary. Do the brakes build up pressure and not release? If everything still seems okay after you do that I would take the bike for a ride around the neighborhood. Stop every few minutes to make sure the disc isn't heating up indicating the brakes may not be releasing properly.
If the master cylinder is working properly, when you pull the brake lever fluid is pumped into the brake line. This forces the brake pads against the brake disc, stopping the bike. When you let off the lever the fluid is allowed back into the master cylinder. If the cylinder does not release the fluid it could put a quick end to your riding. I would not be comfortable letting someone ride this bike very far until I took the master cylinder apart and satisfied myself that it was problem free.
May 24, 2009 | 2008 Suzuki GSX-R 600
Frigidaire Affinity ATF7000E Front Load Washer Logo
178 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
