Question about Sony VAIO VGC-LS30E 1.73GHz Pentium Dual Core 2GB RAM 250GB hard drive - 19in. Display PC Desktop
I have the same problem with sony vaio, white screen with flicker to black. This pc does not have an video output port to plug in external monitor. Any ideas??
  • 32 Answers
You can install a video card that has a dual monitor VGA port.
Matrox makes inexpensive PCI cards.
Posted on Jul 04, 2009
Screen freezes and flickers black on and off
I have had issues with the cable and connector feeding the screen. Double check with an external monitor.
Jan 26, 2014 | Sony VAIO VGN-S380P (VGNS380P25) PC...
I've got a Sony vaio which now on starting up has
Does it seem like it booted up all the way except the screen is black? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 17, 2012 | Sony Computers & Internet
SONY VAIO VGC LS25E. On bootup, all I see is a white screen, nothing else. I hear the POST beep, and various other sounds, but have absolutely no video...except for the white screen. This is an ALL IN...
1. RUN DISK DEFRAGMENT FROM WITHIN YOUR OPERATING SYSTEM OR DURING STARTUP 2. RUN FISK DISK COMMAND FROM MS DOS 3. RUN CHKDSK COMMAND FROM MS DOS 4. IF YOU CONTINUE TO EXPERIENCE PROBLEMS, PLEASE RETURN FOR MORE DIRECT HELP FROM ME.
Jan 26, 2011 | Sony VAIO® VGC-LS25E All-in-one Desktop PC...
I have a sony vaio vgn cs36gj and on the start bar there is a line right across the bottom that flickers every five seconds. I have my screen adjusted to the correct resolution. I have also plugged in an...
90% chances are that this is the problem with your Graphic settings.(go to your Graphic Properties and make sure that Refresh Rate should not be more then 60Hz). Change it to 60hz and restart your machine, This should resolve.
**Please post your feedback and Vote if the problem resolved as per your satisfaction**
Sep 28, 2010 | Sony VAIO VGN-CS260J/P Laptop
White screen. what does it mean?
Your LCD might have gone out, call the sony support number for a service request or take it to your local computer repair shop. Hope this helps!
Jul 12, 2009 | Sony VAIO VGN-CR220E/P Notebook
Ibm thinkpad t43 backlight inverter issue
Did you say the the video output flickers on and off when you connect an external monitor to the video output. If the inverter is faulty this would not affect the video output and the external monitor would not flicker but if the external monitor flickers it would point to a video card problem.
Jun 13, 2009 | IBM ThinkPad T43 Notebook
Sony vaios laptop comes on but screen is white i can hear sound of computer starting up but cannot see anything
To determine if the video card or the LCD screen is faulty, connect an external monitor to the video port on the laptop. Power up the monitor first and the boot up the laptop, the video data will automatically divert to the external monitor. If you get a normal image on the monitor then the video card is OK and the fault is LCD screen or the video cable. If you don't get an image on the monitor then it is a video card problem, and it is a motherboard problem.
Jun 09, 2009 | Sony VAIO VGN-NR260ES notebook
Screen is white
You could have a video controller problem or a LCD screen problem, what you are seeing is the backlighting but no video information.
To check if you have a video problem, connect an external monitor to your laptop and bootup your laptop, if you see Windows booting up the external monitor then the video controller is OK, and your problem is the LCD screen or the video cable connection on the motherboard (may need reseating).
If you cannot fix the LCD screen then use your laptop with an external monitor.
Jan 28, 2009 | Sony VAIO PCG-Z1WAMP2 PC Notebook
MY VAIO SCREEN TURNED WHITE
What type of vaio is this?
First attach an external monitor or go to your friends home ,they may have an old crt monitor or lcd,just remove the video cable from their system and plug it into your laptop video port.
when powering-on laptop -press the FN key and the F7 key at the same time to toggle the video signal - video will show on the external monitor or if not you have to replace your LCD.
The above test will verify if the LCD is bad or you have an inverter problem.
Jan 08, 2009 | Sony VAIO VGN-FJ270/B Notebook
Cant see anything but white screen after bootup
Plug in an external monitor and use the F key with the FN to toggle between lcd and external monitor. On my laptops It is the FN and F5. If the external monitor works the problem is the the inverter board, the flex ribbon cable or the LCD. If the external monitor is also messed up then the problem is probably the video card/ motherboard.
May 14, 2008 | Sony VAIO VGC-LS30E 1.73GHz Pentium Dual...
Sony VAIO VGC-LS30E 1.73GHz Pentium Dual Core 2GB RAM 250GB hard drive - 19in. Display PC Desktop Logo
447 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
