Question about Sansui VHF6010 VHS VCR
I need to record a show
I don't have the manual. Everytime I try to record by pressing record, the VHS tape ejects. How do I record?
  • Sansui Master
  • 520 Answers
Check the tape. The erase tab may have been removed. Try a brand new tape.
Posted on May 13, 2008
You have to make sure the channel on the vcr is set to 04 and the channel on your tv is set to 03. That's how mine works.
Posted on Nov 11, 2007
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
My VHS player will occasionally accept the vhs tape but then it pulls out the film then turns off or ejects the tapes how can i fix it
Unfortunately there is some damage to the drive mechanism of the VCR. This will need to be fixed. I can't say what is causing it, but it is clearly not pulling the tape back inside the cassette before the eject action takes place.
Mar 18, 2017 | Emerson 4-Head VCR Video Cassette Recorder...
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
Vhs tape ejects when pressing record
1. Rejected tapes on a VHS recorder is due to a dry belt that is the transfer belt on ejection tray is worn and needs replacement.
2. Because VHS recorder are now not so prevalent and there are so few repair shops specializing in there repair due to parts acquirement it may be best to get a new recorder.
3. Addressing the belts. The belts usually grips a pulley which in turn turns a gear that moves the ejection tray forwards/backwards when given a certain signal on from the control board. This could also be a worn gear from constant use of the load/ reloading of VHS tapes.
I hope this helps.
Feb 05, 2010 | LG Televison & Video
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
Magnavox TV: Somehow the record button on the remote will not record VCR. It ejects the tape and does not record. Please help. Thank you.
Try Using a new VHS tape. If the new tape ejects when press recording, the recording switch inside your VCR could be defective.
Let me know if you require further assistance.
Aug 26, 2008 | Televison & Video
Lg v181 combo problem with vcr keeps ejecting tapes when I want to record.
The tape load carriage is defective or there is something in the way inside the machine....accordianman
Feb 21, 2008 | LG V181 DVD Player/VCR
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Sansui VHF6010 VHS VCR Logo
119 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
