Question about Whirlpool Ovens
Oven wont come on -I get E1 F5 on display.
  • 6,784 Answers
Self clean latch will not lock
If door not latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Posted on Jul 11, 2009
My whirlpool oven is showing an E1 F5 code. It did it once but I can't clear it now.
E1 f5 code oven - YouTube
? 1:51
https://www.youtube.com/watch?v=5F1vwVpmG9U
Dec 28, 2014 - Uploaded by Jay Dornbos
Door locked then threw the code so now the door is locked and will not open. ...Whirlpool Oven - has E1 F5 ...
Nov 23, 2016 | Whirlpool Ovens
After a power outage my oven is unable to work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(((((((((
Jun 06, 2010 | KitchenAid Architect II KEBK206SSS...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
E1 F5 Error Code RPD-305-PDS14 Whirlpool Double Oven. Woke up to code. Turn Off/On/Breaker and Appears to re-boot, until you turn the oven on, then 30 seconds later back to E1 F5. I replaced the whole...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$RTYH
Feb 12, 2010 | Whirlpool GBS307PR Electric Single Oven
After self cleaning today, the oven will not unlock and shows E1 F5 on the display. What do we do to unlock?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$^TR
Oct 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I used the self cleaning oven and now it wont unlock and it keeps beeping f5, e1 what does this mean and how can i unlock the oven?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&URTGF
Mar 27, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Lost power now oven won't do anything...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^
Aug 07, 2008 | KitchenAid Architect Series KEBC208KSS...
E1 and f5 error/Door locked
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Dec 22, 2007 | KitchenAid KEBC207 Electric Double Oven
E1 and f5 error
May 07, 2007 | KitchenAid KEBC247 Electric Double Oven
Ovens Logo
146 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
