Question about Goodman CLJ30AR32 Air Conditioner
Filter for Bryant plus 90i
I am trying to find a filter for my Bryant plus 90i furnace. It seems to take an odd-sized filter but I cannot find accurate dimensions from any of the manuals, specs, online or offline sites. The Bryant dealership itself couldn't even give me a straight answer (but thought it might be a 20 x 25 x 5). I tried that size but it was just slightly too wide. The next step smaller is 4" wide... Wouldn't that leave too much of a gap? I would prefer to purchase filters via an online store so I welcome any suggestions, advice, etc.
It is prolly a FILXXCAR0024 the exact size is 24.75" X 23.6875 X 4.3125 that is their 1 oddball size the rest u can use a 16 or 20 X 25 from Walmart or menards. The cheaper you go the less filtration you get and less protection for your equipment.
Posted on Jun 08, 2012
  • 284 Answers
Bryant Furnace Filters www.iaqsource.com Every Bryant filter in stock For every Bryant furnace and AC
may want to check on the filter itself and the housing for numbers that could assist its type and size
this site may help you
Posted on Jul 04, 2009
Bryant unit with model# of 310jav042090aaja. Where is the air filter located on this unit?
it is inside the front door where the intake is,if it is part of a furnace,then it uses the furnace filter
Jul 02, 2015 | Filter Heating & Cooling
Why is my furnace filter dirty after 3 days
depends on what you are calling dirty which is relative to each person
Are they so dirty they are clogged or do they just have dust on them
IF they are just dusty then that is normal and it is being pulled from inside the house
If you have a pet door that will cause a lot of dust
The only other way is if there is a hole in the attic or your return air somewhere
Feb 26, 2013 | Bryant Gas Furnace Legacy-310AAV Plus 80...
Carrier HVAC model 58sta090 filter size?
Carrier Furnace Model 58STA090-16120 (58STA09016120 ...
www.repairclinic.com/.../Model-58STA09016120-Carrier-Furnace-Filter...
Carrier Furnace Model 58STA090-16120 (58STA09016120) Filter Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Carrier HVAC model 58sta090 filter size? - Fixya
www.fixya.com/.../t11662616-carrier_hvac_model_58sta090_filter_size
Feb 12, 2012 - Carrier HVAC model 58sta090 filter size? - Air Conditioners ... Main house central air? = 3 tons ... I assume the filter goes in at the bottom of the air ...
CARRIER Base 80 Furnaces
Feb 12, 2012 | Heating & Cooling
Furnace heats up fan turns on then turns off 2min later then back on backoff might finish cycle
Sounds like an air flow problem furnace going off on limit check filter and blower could have a clogged air conditioning. A coil. 20 years plus experience in this fieldl
Jan 18, 2012 | Bryant Heating & Cooling
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Bryant Plus 90i furnace vibration
You have not mentioned if the vent pipe has any anti-vibration mounts or not. If not, use rubber mounts to suspend the vent. It may be transmitting your noise.
Mar 11, 2010 | Heating & Cooling
I have a Bryant Plus 90i furnace and a Bryant2.5 A/C
go mid.range....cfm dont go to hi spd or no cooling pick up
Aug 18, 2009 | Bryant Heating & Cooling
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Dec 09, 2008 | Bryant 462AJC021BA Air Conditioner
Goodman CLJ30AR32 Air Conditioner Logo
2,154 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
