Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Intex model 8110 shuts off after a few minutes when time is set
When i go through the whole process of setting the time to run and locking it the green led light never comes on and then the whole system just shuts off Anybody have similar problem and a solution please
  • 10 Answers
I had very similar symptoms with my 8110, however the Green LED would come on for approx. 1-second before the whole unit would appear to be dead. Watch yours carefully to see if the Green LED comes on for a second. If it does, part of the circuit monitors the electrolytic plates. If it detects a malfunction it shuts down. On my 8110 I found the following. Perhaps you have a similar issue.
On the circuit board there are two connections that go from the terminal strip to the electrolytic plates. The leads on the terminal strip are quite large and it appears when they originally soldered the terminal strip to the circuit board they did not apply enough heat. Over time the solder connection deteriorated and the connection became very resistive and generated enough heat at the solder joint that it finally failed. I cleaned the terminal strip lead and the corresponding pad on the circuit board and re-soldered the connection. While I was at it I went ahead and re-soldered all of the terminal strip leads.
Posted on Jul 06, 2009
Code 88 stays on it hasnt gone off since i plugged it in
This is normal... From here, you must set your cycle time.....Follow these steps... Note: on the 8110 model, you must start your pump and set your pump timer first, then wait 15 minutes to sync your chlorinator to between the pump hrs. If the pump turns off before the chlorinator, you will get a low flow alarm...
If you can't read this, it's from your manual.. If you need help setting the timer, post asking for help setting timer... Good luck...
Aug 08, 2011 | Intex Automatic Salt Water System for ...
Have no owners manual and can't figure out how to set the timer!
code 88
Is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process
If you need the manual you can email Intex at www.email.intexstore.com
Or you can buy the manual on this link below.
http://home-and-garden.become.com/intex-krystal-clear-deluxe-saltwater-system-salt-in-pool-model-8110-owners-manual--compare-prices--sc906782580
Good Luck and please rate 4 thumbs up for the free answer.
Jul 05, 2010 | Intex Automatic Salt Water System for ...
Power shuts down
Sounds like a power supply issue.
If you call intex and tell they you have a power supply problem and a reciept within two years. they should ship you a new one.
Jun 23, 2010 | Intex '10 Saltwater System Pool...
When I try to set the time on my intex 8110 I can set the time & when I leave it for 10 minutes it always goes to flashing 94. Is there something wrong with the pump or maybe it's possible I'm missing...
that sounds really weird. There is no code 94
Try locking it manualy
hold down arrow till beep
now hold up arroe till beep
now with quick pushes set desired hours of run with up arrow
now hold till beep on down arrow then hold down on up arrow till beep
the unit is now locked and should start it could take upwards of 10 minutes
If all else fails you can call intex with a valid receipt up to 2 years of purchase and they will replace it
Hope this helps
Jun 21, 2010 | Intex Automatic Salt Water System for ...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
System shuts off and will not chlorinate
check or replace sensor and check cell if ok possible bad transformer
Jun 20, 2017 | Intex Automatic Salt Water System for ...
Intex Salt Chlorinator - Turns off once set
I had very similar symptoms with my 8110. Part of the circuit monitors the electrolytic plates. If it detects a malfunction it shuts down. On my 8110 I found the following. Perhaps you have a similar issue.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
After going thru the Start up set up our Intex
After setting the time did you remember to re-lock the keypad by pressing and holding the "down arrow" for 5-seconds until you hear a long beep and then the "up arrow" for 5-seconds until you hear a long beep? Several minutes later the Green LED should come on indicating the cycle has started.
Jul 03, 2009 | Intex Automatic Salt Water System for ...
I have an Intex Saltwater System, model 8110. It comes on correctly, I set the time, and the green light eventually comes on, indicating that it is working. A few minutes later, it shuts itself off. I...
I had very similar symptoms with my 8110, however the Green LED would come on for approx. 1 or 2 seconds before the whole unit would appear to be dead. If yours is actually turning on for minutes you may have a different problem or perhaps your connection is intermittent. Part of the circuit monitors the electrolytic plates. If it detects a malfunction it shuts down. On my 8110 I found the following. Perhaps you have a similar issue.
Jun 28, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
524 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
