Pump oil doesn\'t need to filled often. Only when you notice the oil looking creamy or not clear! This applies only to horizontal shaft pumps! If you have a vertical shaft, the pump is non-serviceable. If the pump is leaking oil, then only add as needed! The oil level on any pump is half way up the sight glass if any is available. If no sight glass is available then only half way up! NEVER fill the pump completely up! This can cause oil seals to fail as well as other damage to the pump! Best of luck!
