Question about Sony XM-2150GSX Car Audio Amplifier
I have Sony XM-2150GSX amp on offset cant get it off
My amp has worked fine for while but few days ago stopped working gets power but then switches to offset and wont power subs, checked all fuses and wiring all good and proper but still cant get to work
  • 113 Answers
Check for a short on one of the edges or a resistor on the edge of the board
Posted on Jul 04, 2009
Radio quit working
Sounds like someone shorted the wires...you need to look into the entire butcher job and see what wires were touched. Disconnect everything the butcher did and then see if your battery is still drainning power.
Dec 03, 2013 | 2006 Chevrolet Malibu
I have an XM-2150GSX 760watt sony amp, ive gotten everthing hooked up to it, but for some reason i have power to the amp but not to the subs, i know the subs are good still (i hooked them up directly to...
If you are hooking 'blue wire' (remote turn on for amp) to the power antenna wire (usually also blue) from the radio that could be your problem since the antenna only gets power when the radio is used
try using the switched 12 volt wire you used to connect your stereo power
i will assume all other wiring is correct and if so this should fix your issue - if not write me back with as many details as you can about how you have things wired and i will try to help more
good luck!!
Apr 15, 2011 | Sony XM-2150GSX Car Audio Amplifier
Overcurrent lights comes on whenever my amp is on
this can only mean 2 things, either your over working the amp, which means your amp is trying to push power that it don't have, and it's getting hot which is known as thermal mode. and the other reason can be that make sure amp rms. matches the rms. of your subs.
Mar 13, 2010 | Sony XM-2150GSX Car Audio Amplifier
When i turn my amp up it goes into over current / offset mode and doesnt come back on until i turn the radio off and turn it back on
ive never liked xplodes it always did that to me..check youre wires make sure they are the correct gauges...if you buy an amp always buy from a dealer and make sure they install it correctly ...
Feb 21, 2010 | Sony XM-2150GSX Car Audio Amplifier
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Amplifier keeps running overcurrent
sounds to me like you are overheating the amp, try down tuning the peak level of the amp, and also if there is anything around the amp clear it away, check if the fan is turning on, you may need to replace it,
May 20, 2009 | Sony XM-2150GSX Car Audio Amplifier
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
I am trying to wire and bridge a sony marine 600w sony marine amp
as long as the speakers are wired in parallel it should be ok dont wire them in series as they will overload the amp it is designed to run at 4 ohms
Feb 13, 2009 | Sony XM-2150GSX Car Audio Amplifier
Sony XM-2150GSX Car Audio Amplifier Logo
692 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
