Question about IBM Thinkpad I1400 2621 Planar TV (10L1537) Motherboard
Replacing Bios battery
I have a Thinkpad 600E IBM that I need to change the Bios battery. Can I do it myself and how do I find it.
  • IBM Master
  • 1,684 Answers
Yes, You can change it yourself. The battery is located in the memory compartment on the bottom of the laptop. Do a search on Ebay for IBM 600e battery, they run about 3.00
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 04, 2009
IBM Think Pad 600e Bios locked. Need Unlock Password Please help.
To reset the BIOS password on your IBM laptop read the information from this link.
Apr 01, 2011 | IBM ThinkPad 600E 2645 Notebook
Got an IBM thinkpad with error 00163?? Any help guy's?
This error code means the BIOS Date and Time needs setting.
This is caused by a flat BIOS battery.
Replace the BIOS battery, it will be a battery with a lead and connector and the battery will have yellow plastic surrounding the battery.
Jan 30, 2010 | IBM ThinkPad 600E 2645 Notebook
Error 161 and 163
The ThinkPad 600E is at least 5 years old? If so, have you changed a RTC Battery (CMOS Back-up Battery) 3V Button cell type that goes somewhere inside the Laptop and sits on the System/Motherboard. I hope you put it back the right way polarity is critical. If not then i have no idea to what it is, though someone will be able to help also you might want to try http://www.computing.net/answers/hardware/ibm-thinkpad-bios-error-code/ good luck, Bastian
Jun 03, 2009 | IBM ThinkPad 600E 2645 Notebook
On a ibm 600e, how do I boot from a cd? I'm
ok go to the bios system by pressing esc or F12 or F2 key when the computer restart. After that change the boot sequence. CD drive first after that HDD or follow the instruction that are given by computer in bellow or side, after configure just press F10 for saving.
Mar 14, 2009 | IBM ThinkPad 600E 2645 Notebook
Starting ibm 600e
Hi there.
Errors 161, 192, 163.
All three of these errors are connected to the back up battery.
To resolve this problem:
1. open memory flap on base of laptop (small philips screwdriver required)
2. find the small connector with 1 black & 1 red wire coming from it.
3. disconnect above connector and gently pull the Red&black wires. The backup battery should just pull out from under the casing.
4. get replacement battery. Either
a. call IBM spares (07900 247 490 in UK) and ask for FRU:
02K6502. UK price is about £8 + £15 delivery + VAT.
b. if comfortable with soldering iron: Carefully open the packaging on the backup battery using a sharp knife.
Remove the solder tags from the battery (these are spot welded so need to be cut/broken off). Buy a new CR2025 battery from any computer shop, jeweler, or camera shop.
Using electrical tape, insulate all round edge of battery
Solder the leads onto the new battery - note polarity. Red wire to +, black wire to -.
Using more insulating tape, wrap battery so that all exposed metal is covered.
5. put new battery into laptop (reverse steps 1-3)
6. start up computer, error 192 has gone, but still shows 161, 163. Select OK.
7. reset date & time, and OK
8. when screen shows 'O / I' restart laptop using on/off switch at side.
Good luck and thanks for using FixYa!!
Mar 05, 2009 | IBM ThinkPad T21 Notebook
IBM ThinkPad 600 Hdd error
make sure the Hdd is well connected , and hope its not an HDD failure. Might also want to check see if you didn't disconnect any other wires by changing the battery.
Feb 28, 2009 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad 600E 2645 PC
the following data is from the hardware maintenance manual for the thinkpad 600 series and is readily available from http://www.lenovo.com/support
Symptom or error FRU or action, in
sequence
161
Dead battery.
1. Go to “Checking the
backup battery” on
page 12.
2. Backup battery.
3. System board.
163
Time and date were not set.
1. Set time and date.
2. System board.
173
Configuration data was lost.
1. Select OK in the error
screen; then set the
time and date.
2. Backup battery.
3. System board.
192
Fan error.
1. Go to “Testing the
computer” on
page 7.
2. Measure the voltage of
the backup battery. If
the voltage is not
correct, replace the
backup battery.
3. Fan.
4. System board.
Oct 03, 2008 | IBM ThinkPad 600E 2645 Notebook
Error codes for ibm thinkpad 600E
Your bios battery needs replacing
http://www.bioscentral.com/misc/ibmdiag.htm
Hope that fixes it for you? :)
Jan 06, 2008 | IBM ThinkPad 600E 2645 Notebook
Thinkpad 600E
Error 19990301 on a Thinkpad 600 usually indicates that the hard drive is not properly connected, and error code 19990305 signifies "no bootable device". So, it's the hard drive.
First of all, I would try removing and replacing the drive to see if that cures it. You can get the service manual from Lenovo at http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=LWIK-3SYPX2
If this doesn't fix it, the hard drive is faulty. However, small size hard drives (10 or 20Gb) which suit these older machines are very cheap on eBay.
Dec 18, 2007 | IBM ThinkPad 600E 2645 Notebook
Computers & Internet Logo
330 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
