Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
Yard-man model 12a-979L401 won't start (9 years old)
I put fresh gas, checked oil, new air filter, new spark plug and connected wire, nothing happens when I try to start it. Manual says to adjust gap on spark plug - don't know what that means, or clean fuel line, how do i do that?
  • 496 Answers
My dad always taught me, rest his soul, that basic 101, if you have gas getting to spark, SOMETHING out to happen.
I'll ask a series of questions and propose some possible solutions. Hopefully we'll crack this mystery. Warning, this might be a tad lengthy... ha
1. Is the spark plug firing?
To check the coil that sends spark to your spark plug and the plug itself:
You can remove the spark plug from your engine and reconnect it to the spark plug wire while it just lays on your mower. pull the starter rope (make sure you're holding down the kill lever on the handle). Look at your plug end as you pull the rope.
Got spark? If yes, go to the next step, flagged ***. If no, look at the end of your spark plug that would go into the engine. The "L" shaped finger should be gapped from the small circular shape on the plug... this is the "gap". Your manual may provide specs on how wide this gap should be. If there is no gap, your plug won't work properly. The "L" shape is a soft metal and can be bent... create the proper gap. Try the test again to see if the plug is sparking. If not, you may have an issue with your coil.
***Yes to spark. Let's look at the gas issue now. OPTION 1. I will tell you that in my experience, water in gas is a major culprit for a mower not running. You've replaced all the filters... good.
I'm not sure of your mower, but most models have a "bowl" bolted to the bottom of the carburator. Sometimes moisture can get in the gas, get trapped in the bowl and won't go away or won't allow gas to get to the spark. Loosen the bolt... it's ok if gas from the bowl spills from this, the bowl doesn't hold much gas and it won't drain your tank. Plus, this means your carbuator is allowing the gas from the tank to the bowl. As you are looking at the gas spilled on the mower deck, see if there are beads of water in it. As you know, water and gas doesn't mix. This would be a tell tale of the problem. I would carefully remove the bowl from the carb and wipe it dry, then reassemble the bowl.
To be on the for sure side that you have no more water in your system, you could disconnect your fuel line from the gas tank and drain it out. Use a jar or container... you can see water in the bottom of it. You can reuse the gas too... just don't include the water!
OPTION 2. If your carb and tank are now H2O free and you're still getting to results, you may have a clogged jet on your carburator. This little pin-hole passage allows gas to pass through to the spark. Sometimes a mower sitting up a while, can cause a laquer effect to gas and it can block this passage. Removal of the carburator from the engine is required and a simple pin can be pushed through this passage to knock a "plug" out.
Geez I hope I didn't miss anything! ha
Good luck to you... I hope it's a quick and easy fix.
Posted on Aug 26, 2009
I am completely stumped....Pressure Washer will not start I feel like I have tried everything. Please help
buy a new carburator on ebay for 20.00,the diaghram and all the rubber hoses are shot,that is what ethanol does,eiher try a rebuild kit or wait 2 days for a new one
May 07, 2015 | Cars & Trucks
Why does yardworks 173cc bs engine will start, run, for 2-3 seconds then stop
Bad gas. Drain gas and refill with fresh gas with Stabil. Old oil. Drain oil fill with fresh 30w oil, 16-18oz. Clean air filter and spark plug.. Relpace air filter if dirty. Saving $$$ on this simple tune up is not intelligent.
May 11, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Hadn't used it a couple years, socleand it all up, checked the muffler, spark plug, air filter... all looked OK. filled it up with fresh gas/oil mix and tried to start it per instructions. No resp
The ignition unit is a small assemby fixed to the side of the cylinder with two screws, there is more than one unit type fitted to this model so i cannot give you the part no, most of the units will have the part no. on them, remove the top cover held with three screws, now remove the starter held with four screws, you will now see the ignition unit, pull the cap off from the spark plug, remove the eart cut out wire from the terminal on the unit, now remove the two screws holding the unit to the cylinder, once the unit is of check the top for the part no. check the web for a new unit, refit the new unit too the cylinder, use a feelr gauge to set the 0.3mm gap between the flywheel magnets and the ignition unit core, re connect the cut out wire. Before doing all of this i should have said you need to give the engine a good crank over to check for a spark with the old unit with the cut out wire removed.
Jan 08, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
I have a new[purchased last summer] Yard Man Mdl.: YM320BV 2-stroke, 31cc, blower/vac that will not start. Fuel is fresh, has new spark plug (what should the gap be?) original plug was...
If the plug is black then either there is too much two - stroke oil in the mix or the gas / air mix is too rich due to e.g. dirty air filter. Have a look at these tips for starting weedeaters, they apply also to blowers:
http://www.fixya.com/support/r9230929-weed_eater_strimmer_will_not_start
Jun 09, 2011 | Mtd #TB4SC 25CC 4-Cycle Gas Blower
Yard-man model 12a-979l401, approx 10 years old, won't start. Changed air filter and spark plug, troubleshooting said to clean fuel line, not sure how to do that and is there a fuel filter that I should...
Some manufactures include an inline fuel filter, most however place the fuel filter inside the fuel tank. You should check you owners manual for it's location.
I realize that you changed the spark plug. However, did you also check to see whether it had spark?
Does the motor fire at all? If it doesn't pop and\or sputter when you pull it over then it may be an electrical issue. You should check to see if it is a fuel delivery issue before you mess around with the fuel line. Try removing the air cleaner and spraying a small amount of starting fluid into the carburetor and pull it over. If it fires up for a second or two then it's probably a fuel issue.You can also clean your plug and replace it. Then remove after you have pulled the mower over 3 or 4 times. Check it for dampness. If it's wet your getting fuel. If not then it's an electrical issue. Either the coil or plug wire.
If your not getting spark then it will not matter how clean you fuel line is or how new your spark plug is.
Also how long has the fuel been sitting in the mower before this became an issue? If it's been in there a while then you may have an issue with your carburetor rather then the fuel line.
You should check these things and if you still have a problem repost with the results of these tests.
Aug 09, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
78 corvette that has not been started in 3
1.) put aside about $50 that you are ging to spend... period
2.) drain the oil and remove the old oil filter
3.) install a new oil filter, add new 30W oil
4.) remove all 8 spark plug wire from the 8 spark plugs
5.) remove the 8 spark plugs
6.) spray about 5 seconds of WD40 into each of 8 spark plug holes
7.) spray the remainder of the can into each of the 2 valve covers thru the EGR holes (pull out the EGR valve first)
8.) making certain that you have a full battery charge, turn the starter switch to START for about 5 seconds... if your engine turns then your internals are not frozen... that's good
9.) open another can of WD40 and spray equal amounts into ecah of 8 spark plug holes a second time
10.) turn the start switch on for another 5 seconds and listen for strange sounds... by the way without the spark plugs the engine will rotate more quickly than you normally expect... not a problem because as it turns it is lubricating your internal parts
11.) wait a minute and then turn it on for for about 10-20 seconds while listening for scraping or knocking sounds... if none heard then you are all lubed up and ready to reinstall the spark plugs.
Install new plugs or sandpaper the old with the correct gap ( I believe .035")
12.) if you didn't mark the plug wires not a problem... Google '78 Chevy Distributor Firing Order to find terminal #1 on the distributor cap... usually about the 1 o'clock position
13.) install #1 wire to #1 sparkplug... the driver's side front closest to the radiator
14.) the distributor rotates like a clock (clockwise) and the numbers on the clock starting at #1 is 1-8-4-3-6-5-7-2.... this is the firing order in a clockwise direction
15.) take the next plug wire #8 and connect it to #8 spark plug
Note: the spark plug numbers are cast into the top of the intake manifold for easier identification
16.) conect the remaining wires to their respective plugs
17.) make certain that you have a full battery charge, some gas in the tank (gas evaporates over 3 years) and a full radiator.
18.) Turn the starter switch and listen for the engine to start
19.) If it doesn't start the first time, try again and wait for the gas to reach the carburetor.... try again
20.) if it still doesn't start spray some engine strating fluid into the carbuetor throat and try again... it should start
21.) if it starts but doesn't keep running then repeat step 20. unitl the gas reaches the carburetor and continues to run on its own...!
Jun 23, 2009 | 1994 Chevrolet Corvette
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Mountfield sp470
Hi, first you'll have to change the air filter and the spark plug. now, go buy some hi octane gas. drain the old gas and put the fresh gas in. if this don't solve your problem please write again.
Nov 20, 2008 | Garden
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
1,088 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
