Question about Refrigerators
I have a norcold 3163 rv refrigerator in my eurovan and have had a problem with the burner not staying lit when i release the safety valve. i hear the burner light when i push it in and the green light comes on but after 15 to 20 seconds when i release it it goes out. I have cleaned the burner with alcohol and air pressure as well as the oriface to no avail. could it be the thermocouple? i checked its relationship with the burner
  • pillowpostca Jul 04, 2009
    the info is good but not quite fitting my situation as mine has an electronic ignition should it be the same as a pilot lit oven?
    President:
  • 942 Answers
Hi
Check to following instruction
  • Make sure the refrigerator is plugged in securely
  • Check for a blown fuse or tripped circuit breaker
  • Test the power outlet for current
  • Inspect the electrical cord for damage
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Good luck !!!
Regards
PCmania
Posted on Jul 04, 2009
  • 483 Answers
Some of such issues explained :
http://www.suremarine.com/stove-repair.htm
Fame !
The burner on my 8682 Norcold RV refrigerator will not stay lit.
I take it this is a refrigerator that operates on elec as well as gas, and if so then check the thermocoupling on the unit. If it runs on elec then that is about all that can go wrong.
Oct 08, 2017 | Heating & Cooling
My rv fridge will lite but goes out as soon as the ignition cycle stops
You didn't state the Brand or Model of your refrigerator but it sounds like your flame sensor isn't working.
rv refrigerator won stay lit YouTube
Oct 14, 2014 | Heating & Cooling
Model 12110 IM Norcold-not cooling on AC or Gas..no fault codes coming up
Hi, if the burner lights in the 'gas' mode, the control board is OK. You most likely have a leak in the sealed refrigerant system, and you need to have the leak located and repaired. This is a job for a RV refrigeration technician. If you need to find the nearest Norcold authorized service dealer, go to www.thetford.com, and use their dealer locator menu.
Apr 13, 2011 | Thetford RV Refrigerator - N300 Model -...
I have a Norcold n300 3 way it works on 110 but
try blowing through the gas orifice with compressed air only.
Jul 08, 2010 | Thetford Norcold DE0051 Refrigerator
Gas will not stay lit the lighter wil ignite for about 4 seconds then diminish
Your propane supply may be nearly exhausted, or your gas valve is having trouble staying open.
To check the gas valve, you will need a helper. Turn the fridge off. Open the lower outside vent. Put a finger on the gas valve. Ask helper to turn it on, you should feel the solenoid snap. If you don't feel it release and flame dies out, then gas valve may be defective. Measure the voltage with a multimeter instead of using finger. If voltage remains when flame dies, then defective gas valve.
If the gas valve snaps shut and then flame dies, you are looking at a corroded / damaged / misaliged flame sense. You will need a service manual, or the procedure to clean may be listed in the owner's manual. Either way, clean the electrode assembly, and reassemble. If still same problem, follow high tension wire back to circuit board, and make sure it is on good and tight with clean connections. If still not working, the replace the electrode assembly. If it remains inoperable, then circuit board may be defective. Most RV shops now have the ability to test circuit boards before purchasing a replacement.
Jun 28, 2010 | Thetford Norcold RV Cooler/Freezer
Dometic refrigerator will not stay lit
sand your thermal cupler off or replace it not centing the flam
Apr 11, 2010 | Thetford Norcold RV Cooler/Freezer
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
I have a norcold 3163 rv fridge which is tri powered. Im having problems keeping it lit on propane. I hear and see a clean blue flame when I push in the safety valve, but as soon as I release it the...
I have the same model refrigerator in my 1999 Eurovan. Before you leave for your trip, if you haven't used the refrigerator for some time make sure it will light before you leave and run it for awhile. This will help insure it will light when you are camping. A good trick I learned is to light one of the burners on the stove for a minute before you switch the refrigerator to propane. That seems to help. Also, don't release the ignitor button on the refrigerator until 15 to 20 seconds and then do so VERY VERY SLOWLY . One other trick is set the cooling dial in a different position than the "Start" position. If that doesn't work then turn it back to the Start position. Sometimes it takes several times to get the refrigerator to light but once it is it will stay on.
Jul 04, 2009 | Refrigerators
Grill wont stay lit
These new tanks have a safety device installed in them . If you open the valve quickly or tip the jug the damn thang won't work. Take the tank loose, open all the grill valves and close all valves. Reconnect the tank and SLOWLY open the valve a hair. Light the burners. No need to open the valve all the way. if you do the dumb safety will plug the jug.
May 08, 2009 | Brinkmann Charmglow 810-7600-S Grill
Rv cooktop range 22 series
hi,
it sounds like the oven safety valve is bad, it will reach a point when the pilot will make enough energy to keep itself lit, but not enough to open the gas valve to light. it will need to be replaced. if you are handy you can do this, but make sure you shut off the gas to the range first. you should be able to find a replacement online, if not check with a local LP gas company that sells parts to the public.
Feb 25, 2008 | Cooktops
Refrigerators Logo
322 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
