Question about Kenmore 500 6953 Dryer
Kenmore dryer. Tension pulley was off, put it back on but cant get the belt to tighten up on it.
  • Craig Butler
    Craig Butler May 11, 2010
    You have to push a loop of belt under the tension pulley and on to the motor pulley. See this video
    President:
  • 1,723 Answers
Watch the video
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 04, 2009
How can i tighten the tension of my amana dryer belt, model nde5800ayw
you cant..... just order a new belt, and idler pulley, because the pulley is probably worn.
Sep 16, 2013 | Dryers
Trying to put belt on drier but its to loose what im doing wrong
make sure the belt is around the motor pulley and the idler tension arm.it goes on like a serpintine belt on a car.pull the pulley to one side and then put the belt on the motor pulley and then release the idler pulley it should tighten up your belt.the outside of the belt should run along the inside of the idler pulley.it will almost look like a figure S.
Nov 13, 2010 | Crosley CDE6000 Electric Dryer
No tension on the tension pulley.
Check that the slide/rod /bracket is not jammed on the adjusting mechanism.
Jan 18, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Series 80 dryer and the belt broke. The pulley came off and I don't know where it goes or how to put it back on. I also don't know the routing diagram for the new belt. Please help ASAP I...
it goes on the shaft of the electric motor the belt goes around the drum should be a set screw on pulley reattach to shaft tighten then looosen bracket on motor apply tension and tighten you may have to go to the hardware st ore and get another screw if yours is lost as a tip apply red loctite to the threads to prevent it from vibrating loose they have that at the hardware store or auto store
Jan 15, 2009 | Kenmore 62622 Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Hotpoint belt pulley won't tighten back up
You must have the belt routed wrong. Pulley should be pushing up on belt to tension it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore Dryer: Drum will rotate, but only manually
Best way to confirm if it's a belt/pulley problem is to remove one of the access panels on the back of the dryer. For many models, it's on the bottom, right hand side. Open it and look inside. You also use that access panel to put a new belt on since it can be difficult to do from the front, having to reach past the drum. But if everything is intact, then you should be able to "rethread" the belt around the idler pulley and onto the motor pulley.
Here's a common diagram:
If the belt is OK, but came off the pulley, then most likely, your idler pulley has too much play in it or the spring has lost tension and isn't holding it securely. I'd put the belt back on. If it comes off again, then look into replacing the idler pulley and/or spring.
Oct 20, 2008 | Kenmore 62602 Electric Dryer
Ken more 90 plus serious
hi i assume you cant get on the pulleys . double the belt ant slide your doubled belt under the idle and to the motor you will feel the tension when you put the belt on the motor pulley
Sep 25, 2008 | Kenmore 62602 Electric Dryer
My dryer needs a new belt. I opened the front panel and removed the broken belt but I am not sure how to put on the new one. I know it goes around the drum but does it go in the middle or near the back...
Cheryl the belt goes in line with the pulleys. 1st Put the belt around the drum. 2nd put the belt around the pulley on the motor. 3rd pull down on the idler pulley and set it so that is pushes on the back side of the belt. Remember the ribs on the belt go against the drum. When done the pulley will take up the tension on the belt. Hope this helps.
Aug 09, 2008 | Dryers
Kenmore 500 6953 Dryer Logo
498 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
