Question about Ford 8N Tractor
No fire on new parts 8n ford
Put all new parts and it still has no fire, also what is the points settings to make sure i have them right
  • 3 Answers
0.024-0.026
Posted on Aug 26, 2009
  • 491 Answers
16 to 20 thou should do it.
A clean nongreasy feeler gauge or a match book cover will do.
Posted on Aug 14, 2009
4 Suggested Answers
SOURCE: NOT GETTING ANY FIRE TO PLUGS. TRIED TO CHECK THE
I just had to do the same. I removed grill and hood. Disconnect upper radiator hose. Remove radiator mounting bolt under left side (as you're looking at the front) and loosen the right mounting bolt. Radiator swings to the right to allow access to the distributor and coil. Lower radiator hose can stay connected as long as it will fold on itself without damaging. Remove the coil and distributor cap. Check to see that the rotor turns when cranking the engine over, to eliminate that potential firing problem. Then remove the whole distributor to replace points and condensor. It's a lot easier. Be sure to check gapping on all four lobes.
Posted on Jun 07, 2010
  • 4 Answers
SOURCE: cylinder not firing on ford 8n tractor
change plug or lead if other zylinders are firing
Posted on Jul 15, 2012
  • 29 Answers
SOURCE: water pump leaks through right side stud on 8n ford tractor
gasket not sealing properly you could try to put silicone on the bolt itself let it dry at least 24 hours then try it. you may need a new gasket make sure you tighten them in sequence usually middle right left top bottom to get a flat tightened match
Posted on Nov 24, 2012
I have fire at coil but no fire through sparkplug wires
The problem sounds like it is your distributor. Replace the ignition points and condenser, make sure the points are gapped properly. If you still don't get fire at the plugs, change the distributor cap, rotor, and wires. Points and condenser kit runs $9.72.
http://www.yesterdaystractors.com/ATK7FA_Ignition-Kit-4-Cylinder_14717.htm?gclid=CJzJscSG47sCFXPNOgod31wAqA
Jan 03, 2014 | Ford 8N Tractor
8N tractor
check your push button starter make sure it is working,or my be the points may be stuck
Jun 16, 2013 | Ford 8N Tractor
Points gap for 1953 8 n ford tractor
Here's how to do it:
http://www.ehow.com/how_7368031_set-points-ford-8n.html
set the point gap a .025
Jan 13, 2013 | Ford 8N Tractor
Water pump leaks through right side stud on 8n ford tractor
Nov 11, 2012 | Ford 8N Tractor
How do i get a blue spark
The issue is spark yes/no. The color is not really relevant. Any spark will usually fire the mixture.
Sep 13, 2012 | Ford 8N Tractor
My 8n ford wont start with new carb, points, plugs, condensor, has a lot of spark at spark plugs and a lot of gas with both carbs I have tried, but no gas on plugs when I take them back out and smell for...
I have also changed my plugs, points, cleaned carb, but I can not get the tractor to fire at the cylinders. I have spark but will not crank. What do I need to do?
Jun 24, 2010 | Ford 8N Tractor
Jun 03, 2010 | Ford 8N Tractor
Not getting spark all the time after putting new
Clean the points with an emery board if this doesn't fix it roll the motor until the points are open then short them with a screwdriver if it arcs see if the coil is putting out spark if not get a new coil
Dec 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
No spark for 2n tractor put on a new 12 coil changed points and condersor was runing before i burned out 6 v coil
check the resistor mounted on the back side of the dash, resistor dead no spark. you can strap it with wire to see if it fires, dont run it this way.
Jun 28, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
12 volt 8n ford will not fire, no spark at first plug
Take the wire off the coil and check the wire for voltage.while it is disconnected.
If there is voltage now....... the problem is in the dist or coil.
Pull the dist and check for something grounding the system.
Are the points opening?
If there was no voltage in the resistor to dist wire....install a new wire.
TIP. Be careful how you set the coil onto the dist.
Jun 04, 2009 | Ford 8N Tractor
Ford 8N Tractor Logo
270 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
