Question about RCA 24V511T 24" TV
Rca tv goes black and white when playing dvds
When playing dvds our tv will go black and white approximately 10 minutes into playing. We turn off the tv and wait for a few minutes (3-5) and turn it back on and it will play in color for another 10 minutes. What's my problem? VCR combo is new and also tried replacing cables between vcr and tv. When watching tv otherwise the tv is fine.
  • 3130 Answers
SOURCE: RCA ColorTrak 27" (non flat) connection to VCR/DVD combo
To Make the rca type cables to work or the red white and the yellow , you have to change the INPUT from RF or TV to VIDEO. Good Luck
Posted on Jun 25, 2006
  • 85 Answers
SOURCE: 32F531T color tv loses color after about 15 minutes.
the crt socket of your tvhas a problem,coldsolder the board of your crt socket,if not working replace the crt socket.
Posted on Jun 13, 2008
  • 899 Answers
SOURCE: rca 32v432t tv plays,turnsoff,turnson, and stays in autochannel search mode
your going to need to do a resolder of dry looking solder jobs and or poor solder jobs
this could also be your front control board , try disconnecting it and see if the tv stays on
it is possible that the sensor has gone bad or the crystal needs to be replace or worse the EEPROM
my rca 27 in was doing the same thing , i resoldered the board and it worked great for 7 months
so do a resolder of all suspicious solder and heated components
then let me know what happens
also what is your model # for your rca tv ?
also one of rca's kits for repair is some solder and paste , so that should tell you something in its self about rca repairs ( the solder with the paste is supposed to make it handel heat better )
please give a fixya rating so that if you need more help in your tv , I can continue to help you further , thanks
Posted on Nov 08, 2008
  • 188 Answers
SOURCE: hooking up DVD/VCR combo to directTV and console RCA
I'd first just hook up the DVD/VCR to the TV and get that working. I'm assuming all you need is the standard cable type connection. This will at least your 4 year old happy. Then you can experiment with the S cable. The S cable will give a cleaner signal from the DVD to the TV. then hook up audio and video cables from the Direct TV to the DVD input. The audio and video will be cleaner using S cables and audio and video cables, but stadard TV cable should get you going. You didn't mention what model DVD player you have. You may have to select the correct inout on the DVD for the Direct TV connection.
Posted on Nov 15, 2008
  • 76 Answers
SOURCE: can't find aux channel to view vcr/dvd
use vid 1 or vid 2 input on remote should do that if not then use a differ code in your universl for your tv that makes it work or type 00 should get u there another way go to channel 1 and then down arrow it will go into it if not go into your add channel menu and add them then down arrow
Posted on Dec 03, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
0 characters
1 Points
How can i play vdeogames on a rca f20632se tv
See this is reposted---get your hands on an original remote which will have the TV/video input button on it.
Dec 19, 2012 | RCA F20632SE 20" TV
Went black and white rca f32648
so far no proper details are available regarding resetting this particular TV ( f32648 ) .... i have checked user manual also
have you tried following things
1 - playing different dvds (dvd player )
2 - changing different channels ( cable tv or antenna )
3 - increasing ( to maximum ) & decreasing ( to minimum ) [in menu ]
contrast colour tint black level sharpness
picture presets auto colur colour warmth
4 - auto channel searching ( cable tv or antenna )
even after these trials if picture is in black & white then it is a hardware problem - since it is a rare problem no details are available about which component might have got deffective ...... only the service engineer who opens & checks your tv can tell the exact deffective component .......... sometimes it can be loose connection ( cracks at soldering joints - hit your TV lightly with your hand on left side or right side or on top - if color comes & goes then it is loose connection problem - all soldering joints should be resoldered by service engineer ) ..... or an IC might have got deffective ......... only after opening & checking your tv mainboard exact deffective component can be identified ......
for nearest RCA service center call 1800 336 1900 ( this number got from your TV's user manual - click this link for your TV's user manual - free down load - RCA F32648 model -
Nov 06, 2011 | RCA F32648 32" TV
My RCA 32" TV 2001 is black and white but the menu
Ours had a problem like that. The digibox and the dvd player (anything plugged in with a SCART lead) only played in black and white but the tv menu screen was in colour.
Also anything plugged in with those three little thingies, the red/yellow/white thingies, played in colour so we just bought a converter between SCART and the three thingies.
Sorry for how useless this was, I'm not great with all the technical language. Hope it helped in some way.
Dec 04, 2010 | RCA F32672SB 32" TV
When I turn my TV on it plays just fine for about 10 minutes. Then it goes to black and white. If I turn it off for a few minutes and then turn it back on, the color returns for a few minutes and them goes...
The tube harnesses may be a little loose and when tube warms they short. Try adjusting the wiring harnesses. (Only attempt to do so if you have electronics knowledge.)
Nov 20, 2009 | Philips Magnavox 27MS343S 27" TV
My tv is hooked to cable, when i turn it on I can hear it going on and off and then its goes to a green screen to a snow screen and the sound goes in and out but sometimes it will play about 30 minutes and...
is there video inputs on this tv i would beleive so goto walmart meir radio shack get rf module converter screw cable into convertor and plug set in w/ yellow white red s video plug ins all this does is bye pass the tuner for 15.00 better than replacing the tuner okay good luck
May 03, 2009 | RCA 32V550T 32" TV
Truflat tv/dvd will not play disney dvd
Check the rca guide too see supported formats and check to make sure the disney dvd matches that format.
Feb 02, 2009 | RCA 27F530T 27" TV
Apr 21, 2008 | RCA 32F531T 32" TV
Rca projection screen problem
I have a Toshiba 27D46 TV that comes on great.. but within 5 minutes goes black with a white line horizontal midway across the screen. Any fix solutions? HELP..!!! Chip
Jan 06, 2008 | Standard (CRT) Televisions
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Playing back widescreen problem
The TV itself uses the CTC203 chassis and is not capable of switching between normal and widescreen. This is an issue with your DVD player and not a problem with the TV.
Jul 16, 2006 | RCA F27442 27" TV
RCA 24V511T 24" TV Logo
164 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
