Question about Harma HK-2201 (pn3202042) Keyboard
Function key locked on. Have to press fn key to use normal characters.
  • 40 Answers
Did you spill something on the board? If so, you won't fix that, you'll need a new board. If not, dismantle it and adjust the rubber underlayment. Clean it good. If you did spill something , don't bother trying to clean it. You'll find you wasted your time.
Posted on Jul 04, 2009
My FN keys are backwards
Normally you can do that in the bios
Sep 21, 2017 | Toshiba Satellite L305-S5933 Notebook
How do I get the question mark and backslash instead of green characters
The Question Mark and Backslashes are typed while holding the SHIFT key,
the "Green" characters sound like your FUNCTION keys.
If you're NOT holding down the FUNCTION key or the FN key you may have some kind of Function Lock enabled. (Look for a Fn Lock of F Lock button/light)
Jun 11, 2011 | Acer Aspire 5610-4648 Notebook
My keyboard is typing numbers and characters instead of letters!
Sounds like you have num lock on. The Num lock key is usually the same as Scrlk but to select the Num lock you have to press and hold Shift then press NumLk/ScrLk. A light should light up to indicate the keypad is on/off.
Regards,
G33k
May 11, 2011 | IBM ThinkPad T30 2366 Notebook
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
My function is stuck on, i cannot type on my keyboard unless i hold the function key down the whole time i am typing. is there such a fn key release function.
Normally, if you hold down the "Fn" key, you'll get whatever character or function is printed in blue on those keys. So holding down the "Fn" key, you now have a numeric keypad in the middle of your keyboard. Release "Fn" and things are back to normal.
Which is exactly the opposite of what the question is asking. The person asking needed to press the "Fn" keys to get the normal, white, characters for each key.
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
numlk.jpg To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jan 14, 2011 | Computers & Internet
Restore my acer 3680 back to factor
to restore your system to factory default....restart the system..immediately hold the AltGr key(the one right to the space bar)down...and keep tapping the F10 key...you should screen that says windows is loading file..if not try a couple of times...once you get that screen...navigate through the screen ..this will help you restore system to factory default
let me know if this helps...
regards
Dec 29, 2009 | Acer Aspire 3680 Laptop
Locked keyboard buttons
You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
Press the Fn key and that key and your keyboard will return to normal.
Apr 20, 2009 | HP DC170B Keyboard
Fn key active
This is not because Fn key its Num Lock key that changes jkl to 123. Just turn Num Lock button off.
Apr 09, 2009 | Acer Aspire 4520-5141 Notebook
Toshiba Satellite A45-S250 non-numeric keys locked
Your keyboard logic chip is in need of therapy.
Replacement of keyboard warranted.
Now, I thought that it might be a redesignation of your language code, but that proved not to be the case.
Mar 29, 2009 | Toshiba Satellite A45-S250 Notebook
Problem with keyboard or input of certain keys
hi.. is that a bi-lingual keyboard that you purchased? If so, what model? If that's a toshiba laptop w/ a bi-lingual keyboard, press the left (shift+ctrl) buttons for 10-15secs then release it. You should be able to bring back the normal function of your keyboard. If your having problems pressing the "n" key and it replaces it with a number on the screen when you type it, it's most likely that you enabled the "num lock" function of your keyboard, on Toshiba press FN+F11, on Dell FN+F11 also i think, it may differ on other models, sometimes FN+ Print Screen or Pause (above F11).
Hope this helps.
Oct 03, 2008 | Microsoft Windows XP Home Edition
Harma HK-2201 (pn3202042) Keyboard Logo
94 people viewed this question
Top Harma Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Harma Computer and Internet Expert? Answer questions, earn points and help others
