John Deere L120. When the mower clutch is engaged (switch pulled outward), the engine dies. Appears to be safety interlock related because the engine will recover if the PTO switch is returned to off. The mower deck has been removed for troubleshooting
A possible cause could be the operator presence seat switch. If that switch isn't closed, it will shut down your mower. Also check if you can turn your blades by hand. A piece of wood wedged between the deck and a blade or a piece of rope/wire wrapped around a spindle will stall your engine. Lastly, check your battery. The electric clutch pulls quite an electrical load. If the battery is going bad and the voltage drops too low (below 10VDC) the engine may shut down.
Check reverse safty switch or engine rpm to low to run pto
