Question about Garmin nuvi 885T GPS Receiver
I received an email from Garmin this morning stating there was a new software version..4.60 I should download. I did so and now when I plug the unit into my vehicle the unit says "loading maps" and never ends loading. I left it plugged into the vehicle outlet for over 4 hours and it still say "loading maps" Nuvi 885T
  • 1 more comment
  • dannyearnhar Jul 04, 2009
    battery is 100% charged. I had it plugged up all day yesterday.
    I received an email from Garmin this morning stating there was a new software version..4.60 I should download. I did so and now when I plug the unit into my vehicle the unit says "loading maps" and never ends loading. I left it plugged into the vehicle outlet for over 4 hours and it still says "loading maps" Nuvi 885T. The battery is fully charged!
    I don't understand why erasing ALL USER DATA would allow maps to load properly. It seems to me that the downloaded NEWER software version...4.60 has caused all the problems. Is there a website where I can reload a prior version like 4.40 or something before I erase everything I have entered in the unit. I have many "favorites" in this unit. It would take some thime to re-enter all of them.
    President:
  • 1,383 Answers
First try to reset it press reset button for 10 seconds then still face problem you can get that software from here.
check this link you can ger from here.
http://www8.garmin.com/support/mappingsw.jsp
Posted on Jul 04, 2009
  • 2,071 Answers
Just remove the battery and disconnect from power for 5 minutes and put it again. Also remove map card, this will reset the device. Try it out
Good luck..
Regards:
VOTIT
  • Garmin Master
  • 6,487 Answers
You just need to Charge it up all the way! It does that when the battery is really low.
  • Mark Gil
    Mark Gil Jul 04, 2009
    ok did you already tried resetting the unit?? if not follow this steps
    To perform a master reset, with your nüvi powered off, press and hold the lower right corner of the screen. Next, turn the power on. Continue to hold the screen until it asks if you really want to erase all user data. Select yes. The screen will flicker a bit and then start up like it did when it was first turned on. Follow the directions to set time and location. You will have to reacquire satellites by turning on your nüvi and letting it sit somewhere in full view of the sky. This one time acquisition may take up to 20-30 minutes. The unit may still ask if you are indoors or if you are in Kansas. This is normal. Just answer No to both questions. If you are on the map or satellite data screen, the
    green bar at the top will now read "Locating Satellites." Make sure you leave the nüvi out for the full 20-30 minutes. If you move it or turn it off early the initialization process may not complete.
All of a sudden, my Garmin SP 7200 lost all satellite reception. All the signal bars are blank. Garmin says $190 to repair. Really like this unit but considering another unit. Is the GPS receiver...
Try running and installing or reinstalling the latest update using the Garmin WebUpdater.
download the latest version of WebUpdater software
Usually this will resolve most issues.
Failing that, the GPS receiver is replaceable as per Garmin's $190 to repair.
Aug 18, 2011 | Garmin StreetPilot 7200 GPS Receiver
Why is the update for the Garmin Nuvi 200 $70 on Garmin's website? Shouldn't these updates cost less if I am downloading directly from their website? Is there a free version anywhere?
Map updates are not free. It takes time and money for Garmin to research the new roads, POIs, routes etc.
Software updates ARE free. If you are looking to update the unit's software - download Garmins WEBUPDATER, and after you install it from that link, and plug in your device - your PC will recognize/check and update (if necessary) to the newest version every time.
Maps are written with proprietary software and not available anywhere for a free download.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 14, 2010 | Garmin nuvi 200W GPS Receiver
Garmin 545s : The unit powers up, the keys are illuninated, however, the display creen is blank (black no image). The unit beeps when I push the + and - keys and menue keys, but no display?
I recommend upgrading the system software of your Garmin 545s. There may not be physical damage to your unit, and it may be completely revitalized by replacing the GPSMAP software with the latest version 5.30 (as of January 7, 2010).
  1. Click on "Download" and choose to save the file to your computer.
  2. Choose a location where you can easily find the file, such as the 'My Documents' folder or 'C:\'.
  3. Once the download is complete, go to the location where you saved the file.
  4. Double-click on the downloaded file. This will automatically extract the files to C:\Garmin and run a program to transfer the software update to an SD card.
I hope that helps.
Jan 31, 2010 | Garmin GPSMAP 545s GPS Receiver
Update problem with Garmin Nuvi 255w
I had same problem. I called Garmin customer service who connected me to a computer rep. Garmin hooks with your computer that you have your Garmin plugged into.They can upload the proper software in no time at all.
The rep told me that after I updated my Garmin I might have turned off the unit before it completed updating the new software. You need to wait until the screen with "Where to?" appears.
It works great now. Prepare to wait on hold for a while. I waited just over an hour on Monday, their busiest day.
Feb 28, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Forerunner 305. Problem receiving activities and courses
This turned out to be corrupt data on my machine. I opened the Garmin traing center, backed up all the courses then deleted them inside the Training centre. I then received from device and all was okay.
Jan 12, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin 660
Have you updated the software since you purchased the unit? If not, go to Garmin's site, download WebUpdater and check to see if there is an update to the unit's software. If so, download this and see if it helps. If not, try downloading the same version of the software again. This might help also.
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Voice Prompt
My husband had the same problem with his i2 Street Pilot.
He went to the Garmin web site and downloaded the latest
updated software version. You can then chose the language options, too.
Dec 31, 2007 | Garmin StreetPilot c310 GPS Receiver
Can't update software for StreetPilot C330
I have contacted Garmin several times till I got an acceptable answer. Some of the C330 receivers were sold to car rental agencies and contain software version 2.30. These units cannot be uodated. They are not reconized as a HD letter in "my computer" and mine would not accept a map update.
Dec 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin gpsmap 60csx won't acquire satellites
I found the solution that fixed my 60CSx. You need to make sure you have the latest chipset installed on your device. Go to
https://buy.garmin.com/shop/store/downloadsUpdates.jsp?product=010-00422-00&cID=145&pID=310
and download the chipset type G ver 2.9.
After you have loaded it on your 60CSx, you should be good to go. Just turn it on like you normally do and now you'll see your device retrieving locks w/ the satellites.
Let me know if this helps you out.
Charles
Dec 10, 2007 | Garmin GPSMAP 60CSx GPS Receiver
60CSx will not acquire satellites
to find the firmware version go menu, menu, setup, system, menu, software version.
this will show version and unit id
also the garmin sw should show you this info also
D
Nov 18, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin nuvi 885T GPS Receiver Logo
259 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
