Question about Frigidaire Refrigerators
My Frigidaire Model# FRT22RRHW1 is not staying cold- temp control is on the coldest and the freezer is fine.
josh1856
  • 105 Answers
SOURCE: Frigidaire Sid eby Side
sounds like a "performance problem" try pressing and holding the reset button for 3 seconds.
Posted on Jan 27, 2008
SOURCE: frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Posted on Apr 29, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
Posted on Nov 25, 2008
lojacksdad
  • 121 Answers
SOURCE: Frigidaire Model FRT18L4JB1 frigerator not getting
check to see if freezer wall is full of ice if so you have a defrost problem timer,heater or limit switch
Posted on May 08, 2009
joecoolvette
  • 5660 Answers
SOURCE: Frigidaire model ftr18b freezer works, fridge is only cool
Info relating specifically to the Frigidaire FRT18B5ABB:
1.Refrigerator unplugged remove the bottom back panel. (Access cover with label. The rectangular shaped panel on the back, at the bottom) Place the screws in a container.
Also remove the Kickplate Grille in the front, and the defrost pan.
2.Use the wand tip on your vacuum cleaner, and vacuum this area out. Pay special attention to the condenser coils, and the fan. Use care as you don't want to bend the fan blades. After you have vacuumed up as much as possible, see if your vacuum has where you can attach the hose to blow air through it. An air compressor, hose, and air nozzle would be REAL handy right now! Blow the condenser coils, and all areas clean of any gunk. (Hair, spider webs, etc.) If this is not feasible for you, you'll need some sort of long, thin, dust 'bunny', and have to dislodge this 'gunk' physically. Then vacuum.
3.BE SURE to replace the bottom back panel, (Access Cover)! It is a VERY necessary item! If your fridge doesn't have one at present, make a temporary one of cardboard, and tape it on. This access cover is needed.
If your refrigerator side is only cool, and your freezer is cold, you may have a problem with the Cold Control, (Temperature Control), or the Defrost Timer. (Timer-Defrost)
http://disruptit.com/manualgateway.cfm?pdfwanting=34242&username=anon&AV=123345&I=99.169.118.45
Posted on Jul 05, 2009
What is the factory preset temp for a frigidaire upright freezer? the delivery person set it at coldest #7, but once the unit has been running for 4 plus hours, where should the dial be set?
I believe the Frigidaire owner's manual will give you suggestions. I have a Frigidaire and I keep mine on 4. That is the middle point. Set it there then wait a day or two and make sure you have nothing freezing inside and items in your refrigerator are cold enough for you. It's your personal preference.
Nov 16, 2017 | Frigidaire Freezers
My Frigidaire freezer (not frost free)won't stay cold
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Feb 18, 2018 | Frigidaire Freezers
Does not stay cold. Even with
Sounds like the compressor, or a refrigerant leak. Being a year old I would call Frigidaire and try to get it fixed or replaced under warranty.
Jan 03, 2010 | Frigidaire FRT21H8 Top Freezer...
Frigidaire refrigerator model #FRS26R4AW7 is freezing up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Dec 03, 2009 | Frigidaire Refrigerators
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Frigerator is freezing.
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is too much cold air getting over to the Ref side?
1. The little door is open too much.
check your control setting. You should be able to feel air coming through the channel on the Ref side
2. The cold control is bad causing the compressor to run too much.
Nov 13, 2008 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
105 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
