Question about Intermatic EH40 Energy Controls - Electronic Time Switches - Water Heater
Timer doesn't listen!
I set the clock. then I program all six areas to go on at 10 pm and off at 10:45pm on Sunday only. Switches are in auto mode and run mode. Today, Friday, I come home at 4 and the sprinklers are on! What an I doing wrong?
  • mcabrey Jul 04, 2009
    Thank you. I will look at that. I am guessing I do have all zones set for the same time. Program A and B is new to me, I will need to look at that. I don't understand what that is, but I will look at it.
    President:
  • 1,723 Answers
Do you have all zones set for the same time? Hope not. Make sure you have program 'A' only. You might have a different program set with different times in 'B' program.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 04, 2009
  • Craig Butler
    Craig Butler Jul 05, 2009
    I meant to say the PROGRAMS may be set for the same time. The zones CAN all have the same 'run time' on them. Make sure your program switch is set for the one with the time you want it to run.
DO YOU HAVE a manual for a woods e227659 TM-068-2 timer?
Woods TM-068-2
Indoor 7-Day Astronomic Timer
125V ac / 60Hz 15A / 1875W general purpose
8A / 1000W tungsten 500VA electronic ballast
15A / 1875W resistive 120V ac / 60Hz / 8,3A ballast
FEATURES:
• Up to 7 different programmable ON/OFF cycles, cycles repeat weekly.
• Programming fl8xibilify: u8hts fun on/off automatically at sunset/sunrise,
or at any programmed times you choose.
• ln Sunrise/Sunset programming mode, timer will automatically adjust the
programmed ON/OFF cycles to match current sunrise/sunset times.
• Timer automatically adjusts to daylight savings time
WARNING: TIMER IS INTENDED FOR INDOOR USE ONLY!
BEFORE YOU BEGIN PROGRAMMING THE TIMER:
This timer has in internal battery backup to save all programming.
  1. Plug the timer into wall outlet for 30 minutes to charge internal battery.
  2. After 30 minutes, unplug timer and press the RESET button with the tip of a toothpick or similar object to clear the memory.
TO SET THE CLOCK:
  1. Press SET. PRESS +/AUTO or -/RDM to set the current year.
  2. Press SET. PRESS +/AUTO or -/RDM to set the current month from 01 to 12.
  3. Press SET. PRESS +/AUTO or -/RDM to set the current date.
  4. Press SET. Daylight savings mode (DST) will appear on the bottom of the display. PRESS +/AUTO or -/RDM to set mode to either DST AUTO or DST OFF.
  5. Press SET. PRESS +/AUTO or -/RDM to set the current hour. To change between AM and PM, press +/AUTO or -/RDM 12 timers.
  6. Press SET. PRESS +/AUTO or -/RDM to set the current minute from 00 to 59.
  7. Press SET. PRESS +/AUTO or -/RDM to set the Astronomic function to your zone - North (nor), Central (cen), or South (sou).
  8. Press SET to view the sunrise time. To adjust sunrise time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  9. Press SET to view the sunset time. To adjust the sunset time press +/AUTO or -/RDM. To go back to the default sunrise timer press ON/OFF.
  10. Press and hold SET for 5 seconds to exit clock setting mode.
Note: The timer allows a maximum of 7 programmable ON/OFF cycles.
To program the first ON/OFF cycle: Press SET repeatedly to scroll through setting the clock mode.
  1. Press SET to display ON 1 setting.
  2. Press +/AUTO or -/RDM to select day or group of days you want for cycle 1. Scroll to select either every day, any individual day, weekdays only, or weekends only.
  3. Press SET. Set ON hour by pressing +/AUTO or -/RDM to scroll through and choose hour AM or PM, or Sunrise/Sunset icon for first ON setting. Note: To select Sunset or Sunrise for the ON time, you must scroll through all the AM and PM hours first. If you select Sunrise/Sunset as the programmed ON time, press SET to continue programming OFF setting.
  4. Press SET. Press +/AUTO or -/RDM to set ON minute from 00 to 59.
  5. Press SET to display OFF 1 setting.
Repeat steps 2-4 to program desired OFF time.
To program additional ON/OFF cycles: Repeat steps to create additional ON/OFF cycles (ON 2-OFF 2, ON 3-OFF 3, etc.) up to a maximum of 7 different ON/OFF cycles.
Press and hold SET for 5 seconds to exit programming mode. Note: During programming, if no button is pushed for 30 seconds, the timer will automatically return to standby mode. Press ON/OFF to cancel any setting.
Sun tracking technology: Timer adjusts automatically to changing sunrise and sunset times in sunrise/sunset mode is chosen for any programmed ON or OFF time. For example, if you program a cycle to turn ON at sunset and OFF at 10:00 pm, the timer will automatically adjust ON (sunset) time as sunset time changes throughout the year (and will always turn off at 10:00 pm as programmed).
IMPORTANT! REVIEW PROGRAMMED ON/OFF CYCLES: Press SET to advance through all programmed ON and OFF settings. Make sure there are no overlapping ON or OFF times. Stop at any programmed setting you want to change.
To operate timer: Press +/AUTO until AUTO appears in display. Timer must be in AUTO mode for programmed settings to operate. Plug appliance (such as lamp) into timer and plug timer into wall receptacle.
IMPORTANT: Appliance must be turned ON or be in the ON position before plugging it into timer.
SECURITY (RANDOM) MODE: To operate a plugged-in appliance (such as a lamp) in a random pattern while you are away, to simulate actual use: press -/RDM until RDM appears in display. In Random mode, plugged-in appliance will turn on and off at random, approx. +/- 30 minutes from the programmed settings.
To cancel Random mode, press ON/OFF until RND disappears from display. Timer will now function using your previously programmed settings.
DAYLIGHT SAVINGS (DST) MODE: If timer is in DST AUTO mode, clock time (and sunrise and sunset time) will automatically increase 1 hour on the second Sunday in March at 02:00 am and decrease 1 hour on the first Sunday in November at 02:00 am.
TO OVERRIDE THE TIMER: Press ON/OFF until desired mode is displayed:
ON: Programmed settings will be overridden; the plugged-in appliance will remain on
OFF: Programmed settings will be overridden; the plugged-in appliance will remain off
AUTO ON: Turns plugged-in appliance on immediately until the next programmed OFF time. Press ON/OFF until ON displays on the screen, then press +/AUTO and AUTO will display on the screen.
AUTO OFF: Turns plugged-in appliance off immediately until the next programmed ON time. Press ON/OFF until OFF displays on the screen, then press +/AUTO and AUTO will display on the screen.
RDM ON (Random ON): Turns plugged-in appliance on immediately until the next random off. Press ON/OFF until ON displays on the screen, then press -/RDM and RDM will display on the screen.
RDM OFF (Random OFF): Turns plugged-in appliance off immediately until the next random on time. On/Off times will vary +/- 30 minutes from the programmed settings. Press ON/OFF until OFF displays on the screen, then press -/RDM and RDM will display on the screen.
Consumer Support (800) 561-4321
www.colemancable.com
Dec 12, 2017 | Woods Hardware & Accessories
Woods timer 50029
For the WOODS Model 50029 Indoor 7 day digital timers with Astronomic features.
125Vac 60Hz
1/2 HP
8A / 1,000W Tungsten
15A / 1,875W General purpose
15A Resistive
500 VA Electronic ballast
120Vac 60Hz 8.3A Ballast
Instructions:
Charge the Battery:
Plug the timer into wall outlet for 30 minutes to charge internal battery. Note: You can then unplug the timer from the wall outlet and comfortably hold it in your hand to program the timer.
Clear the Memory:
Press the RESET button with a tooth pick to erase any previous settings.
Note: Inactivity for approximately 30 seconds and the timer will return to clock mode.
To Set the Clock:
1. Press the TIME button to set the current year: Then press the "+" or "-" button to adjust the number from 2012 to 2099.
2. Press the TIME button again to set the month: Press the "+" or "-" button to adjust the number from 01 to 12.
3. Press the TIME button again to set the date: Then press the "+" or "-" button to adjust the number. The maximum date will depend on which month you choose.
4. Press the TIME button again to set the daylight savings time feature. DST will appear on the bottom of the display screen. Then press the "+" or "-" button to set DST AUTO mode or DST OFF mode.
5. Press the TIME button again to set the hour: Then press the "+" or "-" button to adjust the number from 00 to 59.
6. Press the TIME button again to set the minute: Then press the "+" or "-" button to adjust the number from 00 to 59.
7. Press the TIME button again to set the Astronomic function: Then press the "+" or "-" button to select the zone you are in. North = "nor", Center = "cen", and South = "sou".
8. Press the TIME button again to adjust the Sunrise time. Press "+" or "-" button to adjust the time.
9. Press the TIME button again to adjust the Sunset time. Press the "+" or "-" button to adjust the time.
10. Press the TIME button again to finish the setting or press and hold the TIME button for 4 sec that will to back to standby.
To Program the Timer:
1. Press the PROGRAM button once to display the first ON setting.
2. Press "+" or "-" button to adjust the day or group of days you want for the program. Scroll to select from everyday, each individual day, weekdays, or weekends.
3. Press TIME button to set the hour. Press "+" or "-" to scroll through 12-hours AM, 12-hours PM, sunrise time or sunset time for first on setting.
4. Press TIME button to setting the minutes. Press button "+" and "-" to adjust from 00-59.
5. Press the PROGRAM button again to display the first OFF setting and repeat steps 2 through 4 to program.
6. Repeat steps 1 through 5 for additional ON/OFF settings.
7. Press the "MODE" button once, at any time exit time setting or program setting.
Sun tracking technology: the timer adjusts automatically to sunrise/sunset times. For example, program lights to turn On at sunset and Off at 10:00 pm. As daylight hours extend, the sunset time will increase. For example sunset may be at 5:41 pm on Monday, 5:42 pm on Tuesday, and 5:44 on Wednesday. The timer will adjust to this On time accordingly and will always turn off at 10:00 pm as programmed.
To Connect/Operate the Timer:
Plug device in to the timer and turn the device on. Plug timer into wall outlet.
To Operate the Timer / Use Manual Override Function:
Press MODE to choose different function between ON, ON AUTO, ON RDM, OFF, OFF AUTO, OFF RDM
1. ON - load is ON permanently in manual mode.
2. ON AUTO - AUTO mode has been selected and load has been forced ON and will stay ON until a contrary scheduled event.
3. ON RDM- RDM mode has been selected and load has been forced ON and will stay ON until a contrary scheduled RDM event.
4. OFF - load is OFF permanently in manual mode.
5. OFF AUTO - AUTO mode has been selected and load has been forced OFF and will stay OFF until a contrary scheduled event.
6. OFF RDM - RDM mode has been selected and load has been forced OFF and will stay OFF until a contrary scheduled RDM event.
Random Setting Security Feature:
When the random setting is ON, the timer will turn ON/OFF +/- 30 minutes around program on and program off times.
Daylight Savings Time Feature:
When the DST function is on "DST AUTO", the sunrise and sunset time will increase 1 hour on the Sunday of the second week in March at 02:00 am every year. It will then decrease 1 hour on the Sunday of the first week in November at 02:00 am every year. For example if sunrise is 6:12 am on March 9th, it will be 7:11 am on March 10th.
Dec 16, 2013 | Hardware & Accessories
Problem of Utilitech digital 8 outlet power strip timer
Copy following link to identify exact timer, and download possible manual.
http://waterheatertimer.org/GE-timers-and-manuals.html#striptimer
With this particular timer, press MODE and PRG button to clear timer programming.
When programming is complete, press CLK button to enter current time setting and end programming.
Then press Mode button until Auto indicator displays.
Make sure current time is correct, and that correct am-pm selected.
Make sure that on-and-off programs are set for same days-of-week, or conflict will cause timer to work erratically.
If timer is defect, buy another timer at Lowes and return defect in new package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 22, 2012 | Hardware & Accessories
Model dehumidifier DDR2611/4011, how do you set the timer? What is the on and off timer for, and the 24 hours?
Boy you know you're in trouble when a web search for your product gives fixya on page 1 google.
There is a product manual for your dehumidifier Sept 2012: but it doesn't say how to set the timer. What a doofus manual.
http://www.danby.com/cms/products/en_manual/Manual_for_DDR26114011_%282%29.pdf
There is a customer care phone number:
http://www.danby.com/en/CA/customer_service
On and OFF are probably manual override, so you can operate unit without timer.
24 hour means a 24-hour military-time clock without am and pm. So 1pm is hour 13, and 8pm is hour 20, and 1am is hour 1, etc.
+/- set the humidity
Best guess for Seting the timer.
Press and release clock (timer) button. You may have to press and hold.
And probably auto start is first thing on menu.
Press + or - button to select start hour from 1 thru 24.
Press clock (timer) button again.
And probably auto stop is next.
Press + or - buttons to select stop hour from 1 thru 24.
Probably you press clock button again to exit timer programming.
Sep 06, 2012 | Hardware & Accessories
After I set my #055671 2-outlet timer to my turn on and turn off times, I cannot get the my lamp to turn on automatically. What setting should the timer be set on ?? Auto off, Auto on? or what?
There is no repair for defective timer.
I suggest setting timer programs, and then press clock button and timer returns to current time.
At this point the timer is operational, and then do not mess with manual override button.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Correct setting is either AUTO ON -or- AUTO OFF setting.
Auto ON, means lamp turns ON immediately and programming resumes at next set point.
Auto OFF, means lamp turns OFF immediately and programming resumes at next set point.
So you have to wait for time to arrive at set point to see if timer is working.
Troubleshoot from link above:
Check that correct time is set.
Check programming for conflicts and overlaps.
For example ON 8:00 pm Tuesday and OFF 10:00 pm All-days-of-week will cause timer not to operate as expected.
Test outlet with cheap circuit analyzer to ensure that electrical problems are not causing problem.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Hardware & Accessories
I have a GE Heavy Duty Digital Timer product # 15117. It also says it is a Jasco Product. I am having a problem getting the clock function to work. I can set the time yet I do know see where there is an...
My auto function on my GE outdoor timer didn't work orginally. So, I programmed the "on" time to be 5 minutes from the current time (10:15 p.m.), and the "off" time to be the time I wanted (10:30 p.m.). Then I put it on automatic and waited for 10:15 p.m. to arrive. It turned on. Then, I set the "on" time to 5:30 p.m. and it works fine now. Apparently, it has to cycle through the "on" time in order to activate the auto function.
Dec 10, 2010 | Garden
Set timer for the 7-day outdoor timer i.e. 5:00 pm on and 9:00 p.m. off Also set the clock ~ should it be left 'on' for the timer to work? Have lost the manual our programmer
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Dec 05, 2010 | Intermatic HB88RC - 7-Day Programmable...
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
Setting the delay on the oven
To correctly proceed you have to know the format the timer program is working in. SO you need to know
1Time format IE 12 hour AM - PM or 24 hr military time 2If a day, date is required M-Sun...or IE Sat 12th of March...(some times this is not a peramiter needed)
With the clock and calendar set the delay time should require a "timed mode setting" prior to being able to set the timer. Once in this mode you will have 1 of 3 ways to set the time delay depending on how the timer is set up to read your instructions. .
1 the actual time of day it is to start (set in actual clock time like the equalivant of 3:05 PM or if in military time, 24hr clock 15:05) or 2 the actual delay time until the program is set to start (again set in hours and minutes 2:10 = 2 hours and 10 minutes from now) 3 also is the stop time, when you want to program to end (also set in the format the timer is programed to recieve instructions)
Also the calendar could be waiting for input as to which day to start the program
Jun 12, 2009 | Kitchen Ranges
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Intermatic EH40 Energy Controls - Electronic Time Switches - Water Heater Logo
124 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
