Question about Sony Cyber-shot DSC-W50 Digital Camera
How to set up a dsx6 for a helicopter?
Unable to sort servos to channels.when aileron servo operated it also moves three others,also when engine servo is operated it moves all servos.
3 Suggested Answers
SOURCE:
  • 221 Answers
SOURCE: Sony DSR-1800 Lost Lock
check the condition of the pinch roller. a bad pinch roller can cause this problem - a tape plays for several minutes, then has problems. what happens is the tape slowly moves up or down on the roller instead of traveling in a straight path. this is caused by the roller becoming worn or glazed and not being able to provide traction to pull the tape through.
Posted on Sep 25, 2007
  • 13 Answers
SOURCE: losing focus
Usually this is a back focus problem; also called a flange back adjustment.  If the back focus adjustment is possible on this camera, zoom out wide - open iris all the way - and adjust focus and lock position.
Posted on Aug 29, 2008
What and where is the servos
  • A servo is a mechanism, usually a motor of some sort, that drives another mechanism. On a passenger aeroplane, for example, the control surfaces are too difficult for the pilot to operate because there is so much wind pressure against them, so they use hydraulic servos to move the elevator, flaps etc.
  • On a car, the drive by wire throttle control is a servo, which is electronically controlled by the computer, depending on the throttle position under the driver's foot.
  • In effect, the power steering ram on a car is also a servo, which is powered by the p/s pump, and controlled by the valves in the steering column.
  • On a smaller scale, the air conditioner has servos that open and close the relevant air duct flaps when the dashboard controls are shifted to control the flow of air in the car. Please note that on older cars, and some new ones, these flaps are not controlled by servos but by cables.
  • The remote controlled central locking on a car has servos in the doors that open and close the door locks when the remote button is pressed. On some cars these door lock servos are small electric motors, on others they use vacuum operated pistons, also called servos.
  • Hope this answers your question!
Feb 16, 2015 | 1999 GMC Jimmy
How do I adjust dual aileron servos
If your talking about 2 servos per aileron (4 total) I think you'll have to use 2 "y" connecters and sync the mechanically. I don't think it has provisions for 4 aileron servos. For 2 you adjust them in sub trim.
Dec 05, 2014 | Spektrum Dx6i Computer Radio
No signal to the helicopter
Check all wires to the servos in the copper. They do come loose and get croted, clean your connection and try that, worst case, you may have to replace the servo. Must hobby stores have them.
I hope this helps you
Jan 25, 2014 | Syma S026G 7" RC Remote Control...
I have a FDX 3.5 channel helicopter when it goes up it constantly flies backwards
The swash plate is broken or the servo gear set is binding.
Set the trims again.
Reverse the trims on the transmitter.
Pull the servo that controls the swash plate and re locate the arm.
Feb 19, 2013 | Toys
03 dodge caravan, 105,000 miles, 2.4L transmission will shift in all gears but will not go into overdrive from 3rd gear. when it does shift to overdrive i try to speed up on the gas and it shifts back into...
I'm afraid that the transmission's O/D solenoid malfunctioning or kick down cable may be misadjusted if so equipped.
looking at a rebuilt transmission if you plan to keep the Caravan.
Or, alternatively, could get a low mileage transmission from a salvage yard and have it installed.
Servos/Accumulators The servos are hydraulic pistons and cylinders. They resemble the hydraulic actuators used on many other machines, such as bulldozers. Hydraulic fluid enters the cylinder, under pressure, and forces the piston to move to engage the band or clutches.
The accumulators are used to cushion the engagement of the servos. The transmission fluid must pass through the accumulator on the way to the servo. The accumulator housing contains a thin piston, which is sprung away from the discharge passage of the accumulator. When fluid passes through the accumulator on the way to the servo, it must move the piston against spring pressure, and this action smoothes out the action of the servo.
Hydraulic Control System The hydraulic pressure used to operate the servos comes from the main transmission oil pump. This fluid is channeled to the various servos through the shift valves. There is generally a manual shift valve, which is operated by the transmission selector lever, and a shift valve for each up shift the transmission provides.
Most automatic transmissions are electronically controlled; electrical solenoids are used to control the hydraulic fluid. The shift solenoids are regulated by an electronic control module. Shift timing is regulated through sensor feedback information provided to the electronic controller.
On older transmissions there are two pressures that control the shift valves. One is the governor pressure which is affected by vehicle speed. The other is the modulator pressure which is affected by intake manifold vacuum or throttle position. Governor pressure rises with an increase in vehicle speed, and modulator pressure rises as the throttle is opened wider. By responding to these two pressures, the shift valves cause the up shift points to be delayed with increased throttle opening to make the best use of the engine's power output.
Older transmissions also make use of an auxiliary circuit for downshifting. This circuit may be actuated by the throttle linkage, vacuum that actuates the modulator, or by a cable or solenoid. It applies pressure to the downshift surface on the shift valve or valves.
The transmission modulator also governs the line pressure, used to actuate the servos. In this way, the clutches and bands will be actuated with a force matching the torque output of the engine.
Aug 09, 2010 | 2003 Dodge Caravan
I have a 1997 Dakota 121,000 miles and replace the transmission 15,000 miles ago. I bought this from Ebay. Worked fine till now and it won't shift into low when you stop and doesn't shift to over drive...
prev.gif next.gif DRIVE TRAIN
  • Servos/Accumulators The servos are hydraulic pistons and cylinders. They resemble the hydraulic actuators used on many other machines, such as bulldozers. Hydraulic fluid enters the cylinder, under pressure, and forces the piston to move to engage the band or clutches.
  • Jul 14, 2010 | Dodge Dakota Cars & Trucks
    Have a 5#10. Even on full battery the tail wobbles left to right and the heli rotates right continually even when trimmed fully to the left - can you help?
    REMOVE CONTROL HORNS AND SET SERVOS TO CENTER POSITION WITH RADIO AND RECONECT HORNS TO SERVOS ,COULD HAVE SLIPPED ON SERVO SPLINES DUE TO A HARD LANDING.
    Jan 20, 2010 | Walkera HM5#10 RC Helicopter
    Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
    Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
    Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
    Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
    This worked for me on my Blade and using the same Gyro on a self build 450 heli.
    Helimangler
    Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
    Sony Cyber-shot DSC-W50 Digital Camera Logo
    55 people viewed this question
    Top Sony Cameras Experts
    james laughton
    james laughton
    JonSnell Electronic
    JonSnell Electronic
    Dan Dangel
    Dan Dangel
    Level 1 Expert
    Are you a Sony Camera Expert? Answer questions, earn points and help others
