Question about Lexmark X5495 Printer
Have installed and uninstalled reinstalled attempted diagnostics but get a file missing or usb required (it is connected by a usb cable).
  • 40 Answers
Make sure you uninstall properly. unplug the printer usb cable and turn off the printer. Control panel/ add remove progs. Remove the lexmark software. Restart your computer. Install the software for the printer again, plug in the usb. Windows should see the printer and will ask you for the software if it can't find it. Point to it and it should work. If that doesn't work go to the device manager and install the drivers. If that doesn't work , go to the control panel and printers, make sure you don't have another printer installed and selected as the primary at the moment. This should all work if your printer is o.k. If not, the usb cable , swap it for another to test it.
Posted on Jul 04, 2009
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
Tip
My phone software suite does not install correctly on Windows.
This happens when the first installation of the software had not been successful .
What usually happens is that wrong system registry cannot be deleted when uninstalling software, or overwritten when reinstalling, therefore uninstalling and reinstalling the software does not fix the problem.
A bad setup happens often because you connect the USB data cable before installing the software, The firewall or security software had not been disabled, when you are asked if to allow a change to system during setup and you deny, when your account does not have administrator privileges, or when Windows has a problem.
What you can do is the following:
Unplug the USB cable.
Uninstall the software.
Do a system restore to a date before installing software for the first time.
Disable antivirus, firewall and security software.
Install again the software. Start software setup with USB cable unplugged.
On Vista, to start the setup, locate the installer file (eg. setup.exe or install.exe) and instead of using double click to run the file, click the right button of mouse and chose "Run as Administrator" from the dropdown menu.
Ensure that you always allow changes when asked by the system.
Connect USB data cable with device on when asked.
If that does not work, then Windows has a problem, in that case you may need to reinstall windows.
on May 23, 2009 | Samsung SGH-R225m Phone
Windows vista - ZTE AC2726 wireless data modem HSD USB Card unins000.dat file
http://www.4shared.com/file/E2DmPGFU/unins000.html?refurl=d1url
same here . use this file and put to the missing folder. then try to install or uninstall
Apr 22, 2012 | Computers & Internet
I have an Acer Apire 3680 - 2576 laptop, have difficulty installing All in-one Office jet 6210 series printer, during installation, the printer is detected but connection breaks after detection leading to...
Sounds like your cable is bad or the printer itself is malfunctioning.You may be able to uninstall it and find a more updated/better driver then reinstall it.Use a registry cleaning software first such as CCCleaner etc.to clear references in the registry and to remove any temporary files used with your previous attempts at the install.Restart you machine then try the reinstall.If after your attempt to reinstall fails again,you should consider (malfunctioning port,bad connection cable or the printer itself is defective.Hope this helps........Lee
Nov 05, 2011 | Acer Aspire 3680 Laptop
Computer can't recognize camera
Did you have the vcamera connected while you installed?
Try uninstalling and reinstalling ( after a boot) with the camera disconnected) Once the software is completed connect camera to be discovered.
Please rate my help++++AThanks for using FIXY
Jun 19, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
My windows xp was reloaded and now when rehooking up my 7200 all in one, its not working. All wires are connected, original installation disk was used.
Did you install the printer software and drivers before you connected the printer to the computer by a USB cable? Uninstall any drivers that have already been installed then restart. You can get the drivers again from the web site, http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers . Wait until the software asks you to connect to the printer before connecting the USB cable. If you are connecting to a router for an ethernet connection, then that can be cabled together before installing the software.
If the drivers were installed correctly, start diagnosing a problem with the cables. Try new cables, changing ports, and a known working device on the port. When you reinstalled XP, did you include the motherboard drivers specific to your machine (that will have the USB and ethernet drivers)? If you missed those steps, you may need to uninstall the printer before doing that update and then restart.
I hope this helps.
Jan 29, 2010 | HP Office Equipment & Supplies
Scanning
Hi saly_60,
You can try the following steps to resolve the issue:
1. Connect the USB cable directly to a USB port on the computer Ifyou are connecting the device through a USB hub* or other USB device,disconnect it and try connecting directly to a USB port on thecomputer. If successful, the problem may have been with the device.
*Somescanners are powered by the USB connection. This is why connecting thescanner through another device, such as a USB hub, may prevent thescanner from communicating properly with the computer.
Connecting the cable to the your device.
usbtoprtr.gif Connecting the cable to your computer.
2. Check USB Connections Youshould disconnect and reconnect the USB cable at both ends to ensurethere is a secure connection on the device side as well as the computerside. It may also be necessary to try a different USB port on thecomputer. Additionally, you may need to disconnect other USB devices,temporarily, in order to determine if a conflict exists. .
  1. Disconnectone end of the cable and then reseat it ensuring the cable is firmlyseated into the USB port. If the USB cable is plugged into a hubinstead of directly into the computer, try connecting the USB cabledirectly into the computer.
  2. Repeat step one to reseat the cable on the other end.
  3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  4. Make sure the correct USB cable type is being used.
  5. Incorrect (A to A) USB Cable
    Correct (A to B) USB Cable
3. A device attached to the computer is blocking communication If you have more than one device connected to your computer, thenit is possible that some other device is blocking proper communication.
  1. Check to see if there are any devices (other than USB keyboards or mice) connected to the computer.
  2. Disconnect the device(s) and restart the computer.
  3. Once the computer has restarted, attempt your process again.
4. Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
5. USBSCAN.SYS USBSCAN.SYS is a Windows system fileand required by the scan driver. If the system file is missing, anerror message will appear while installing the scan driver or willappear when attempting to scan. Search for this file and direct theinstallation to the appropriate path.
Search USBSCAN.SYS file on Windows XP:
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, download a copy of usbscan.sys from here (Right click and select ‘Save Target As’).
    1. Ifthe file exists and a message appears while installing the scan driver,direct the installer to the appropriate path. For example,C:WINDOWSsystem32drivers.
  8. Close the 'Search Results' window.
Search USBSCAN.SYS file on Windows Vista:
  1. Click the Start button.
  2. Inthe Start Search box of the Start menu, type 'usbscan.sys' (without thesingle quotes) and then press 'Enter' on the keyboard.
  3. Once search has completed and if the file does not exist, consult the computer manufacturer.
Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them. Caution:Uninstalling means deleting software, such as MP drivers, from thecomputer. Once the software has been deleted the unit cannot be usedthrough the computer until the software has been reinstalled.
Note:Login as a user with Administrator privileges to uninstall onWindowsXP/2000. Turn off any programs running in the background, suchas antivirus programs and firewalls before begining.
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
6. Reinstall the Drivers
Use the CD-ROM that came with your printer or download from canon website.
Sep 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP620 is not recognized by PC
Make sure you do not have it plugged in before you start the install. Also for the next install attempt, plug the cable in to a different USB port than the one you;ve previously tried.
May 23, 2009 | Canon PIXMA MP620 All-In-One InkJet...
My wireless internet stopped working all of a sudden and now it is not even recognizing a wireless connection even though I have the Compact Wireless-G USB Network Adapter plugged in and the software is...
first check your cridit.may be still some file remain in the program file or commen fil, go to the files and delete the files,again install the program.another reason your pc support file not support the program.inthis case you should formot the coumputer and reinstall the recovery CD
Jan 15, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Lexmark X5495 Printer Logo
63 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
