Question about IceBox IBFS1 LCD Television
Mine has the same problem, orange LED with humming sound coming from the speakers etc.
  • 21 Answers
I had the same problem with my Icebox. Orange light is on and humming sound is coming from speakers. Icebox dealer (www.lordantech.com) that sold me this unit fixed the motherboard and it is working again.
Posted on May 22, 2010
    Problem Solver:
  • 14 Answers
Someone brought one to me to look at..same problem. Checked power supply (easy to check, take off bottom cover and measure voltages on connector. standard 5, 3.3, and 12v outputs going to maine board.) Power supply was fine. took out main board and noticed several 100uf,16v caps that seemed to be bloated. replaced them and the unit turns on. Only thing i'm not sure about is the time it takes to initially turn on. when you first turn on main switch in back, the front led flashes green for about a minute then the LCD comes on and says "loading" which takes about 2-3 minutes, then the unit goes into standby mode (red Led) the unit will turn right on and off again quickly as long as the main switch in the back is not turned off and on again. Is it normal for it to intially take so long to boot? I do not know the normal operation as this is the first i attempted to repair.
Posted on Mar 02, 2010
LG 55LS4500 55 in. TV has sound through speakers, no audio except a hum from headphones and the optical digital to analog output fiber lights up but no sound output What board is bad?
Hi Louis,
The audio circuitry is located in the main board. Try unplugging the TV for a while and try again if the audio comes back.
I would suggest to check all your settings in the audio section first and if everything seems OK then the main board should be replaced.
Feb 26, 2017 | LG 55LS4500 55 Inch 1080p LED LCD HDTV -...
I'm getting a low background noise coming from the tv. Any suggestions on how to stop this annoying problem?
is it a humming sound or a shhhrhhhr sound. humming is interference from the tv, lead may have fell down on to the board near to the transformer... shhhrhhr sound is weak capacitor and/ or maybe a damaged speaker.
Sep 22, 2013 | Samsung UN65F6300AFXZA - UN65F6300AF 65...
HP Pavilion DV7-1135nr laptop internal speakers won't play
try installing proper drivers for the AUDIO CARD! the orange led only indicates the HTK HOTKEYdrivers are working properly, it does NOT says a thing about audio card drivers! so i suggest you to install proper drivers for audio playback!
Apr 05, 2013 | Computers & Internet
Humming sound when I record
Sounds like it might be feedback from another source or perhaps a loose connection. Try moving the microphone away from power sources or anything that might cause feedback, such as speakers etc.
Apr 24, 2012 | Samson Meteor Mic - USB Microphone
Westinghouse Icebox has a Orange Indicator light and a static hum. I have not used the ICEBOX in almost a year, as I was walking by I noticed the Red light Flashing so I unplugged and plugged back in. ...
I had the same problem with my unit. Amber light was on and humming sound comming from speakers. Motherboard had to be repaired by ICEBOX dealer that sold me my unit. Their website is www.lordantech.com
Jan 31, 2010 | Televison & Video
I recently bought the below record player; http://www.robertopiecollection.com/Application/Products/steepletone/record-players-GB.asp thinking buying a brand new player would mean having no problems with...
Sounds like a bad ground loop or open shield to the signal path, or feedback from its own speaker or motor. The output of the stylus is so tiny that any electromagnetic noise can easily loom large if it leaks into the signal path.
Be advised that turntables and speakers should never coexist on the same platform or speaker vibration will feed back into the stylus, get amplified again and eventually overdrive the electronics and maybe blow the speaker, which begs the question - how did they get away with it back then? One answer is that there was never any real bass from one of these things.
Try it with minimum volume and work your way up. With the tonearm lifted and the platter turning, listen for audible hum coming from the mechanism itself. If you can hear it, so will the stylus when it's on the platter.
Jan 19, 2010 | Audio Players & Recorders
No audio, no indicators but blinking green LED by power switch.
Replace elco C61 (68uF/450V) ; it is empty or almost empty.
Also remove the dark-brown glue carefully. The glue turns from light to dark brown by heat and becomes conductive (some Mohms)
www.tvman.nl
Jun 25, 2009 | Creative Labs Gigaworks S750 Computer...
Loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Dec 16, 2008 | KLH HTA-4906 System
Strong humming sound coming from the over head speakers
are you running a stand alone dvd player or is it built in?check all plugs for sources coming ineg.dvd,vcr,xbox etc,if one is not in all the way,this will cause a hum.
Oct 20, 2008 | Sony DAV-C770 System
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
IceBox IBFS1 LCD Television Logo
200 people viewed this question
Top IceBox Televison & Video Experts
Are you an IceBox Televison and Video Expert? Answer questions, earn points and help others
