SOURCE: Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
SOURCE: KitchenAid Gas Range Model KGRT:
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
SOURCE: kitchenaid glass cooktop element won't heat
You will need to check the "infinite switch" for that burner. Below is a video to show you how to do that. The model is different but the test is the same. Here is the switch if you should find it bad.
