Epson Stylus Photo 895 InkJet Printer Logo
A
Anonymous Posted on Sep 26, 2014
How can I cancel a build up of prints? when I press print it spews out a back log
Paul Delaney
Level 2:
Sergeant:
  • Expert 160 Answers
  • Posted on Feb 20, 2015
Paul Delaney
Expert
Level 2:
Sergeant:
Answers
160
Questions
0
Helped
63092
Points
524
From windows start
run services.msc
Select Print Spooler and click Restart to stop and start the print spooler this will remove queued docs from computers print queue
How to stop printing
While your question is not quite clear, I will provide a couple of suggestions. Usually when you press the cancel button, it pauses the printer and then you must use the arrow keys to select cancel job and then press the checkmark. Also check any computers to make sure that they do not have a job in their print queue. If the printer does not send back a job complete command, sometimes the computer will keep resending the job. Failing all else, restart your computer and your printer. Are the pages that are printing gibberish or is it the correct print job? If gibberish, you might have a corrupted print driver or the file you are printing might be corrupted.
Why is the light flashing on the right side
If the light flashing is the "light bulb like button" or the "Ready/Light" button, it means that either the printer is:
• The printer is busy receiving and processing data or printing.
• The printer is printing a directory, font list, menu settings pages, or Print Quality Test Pages.
If it's Busy:
• Wait for the message to clear.
• Press and release Cancel to cancel the print job.
• Press and hold Cancel to reset the printer.
If it's printing a directory, a font list, menu settings pages, or Print Quality Test Pages:
• Wait for the pages to print. The Busy message is displayed as the pages print. The Ready light is on when the
printing stops.
• Press and release Cancel to cancel printing.
Our printer was down (off) for 5 days awaiting toner. People continued printing to the unit building up a HuGE number of documents for printout. How do I cancell print jobs in the entire local print cue?...
Who normally looks after your IT / printers as it would be best to contact them. However if you want to sort it out, depending on the local setup, you will need to e.g. on Windows log onto the print server and delete all the jobs from the Devices and Printers dialog. On UNIX you would type something like sudo cancel printername. We would need more information to successfully fix the problem.
Have a print job in the printer that i want to cancel. have unplugged the machine from the network, unplugged the machine from power. when i turn power back on, it start printing 500 page job that i do not...
Press the [PRINT MONITOR] key in the lower right corner of display. If fascimile option is also installed, it would say [SYSTEM MONITOR] key in same location. Anyways, after in print monitor screen, select the job that you want to cancel and press [CANCEL] key. Press [YES] to cancel. Press [DONE]. You might want to pull out all of the paper trays so the machine can't print while cancelling documents. Let me know.
1helpful
2answers
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Laserjet 4100 cancels printing jobs
If you can do the following and email me the output I should be able to help you.
Print the event log
The printer’s internal event log stores the last 20 errors and can be printed at any time. To print the
event log:
1 Press MENU until INFORMATION MENU appears.
2 Press ITEM until PRINT EVENT LOG appears.
3 Press SELECT to print the event log.
[email protected]
6helpful
2answers
Unable to cancel a job
Sounds like the printer spool is frozen.
Assuming you're using WinXP and logged in as an administrator (or with admin permissions)
START
Control Panel
Administrative Tools
Services
Locate the "Print Spooler"
Right click on this and choose "restart"
This will restart the print queue and will probably try to print the job again or delete it properly. If it tries to restart, just right click on the printer job and choose cancel again..
You may need to repeat but that should at least get you back up and running with other print jobs again.
32helpful
Printer will not cancel print job
START
Control Panel
Services
My iP8500
Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights
in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
4) When The LED lights in green, press the Resume/Cancel button the specified number of time(s) according To the function listed in the table below. (Each time
the Resume/Cancel button is pressed, The LED lights alternately in orange and green, starting with orange.)
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation
completes, the printer returns To the menu selection mode automatically.)
<Destination settings procedures>
in the destination settings mode, press the Resume/Cancel button the specified number of time(s) according to the destination listed in the table below, and press
the Power button.
Note: After setting the destination, confirm the model name in service test print or EEPROM information print.
[See 3.4. Verification Items, (1) Service test print, or (2) EEPROM information print.]
To the top
Time(s)
LED
Function
Remarks
0 times
Green
Power off
When the print head is not installed, the carriage returns and
locks in the home position.
1 time
Orange
Service test print
See 3-4. Verification Items, (1) Service test print.
2 times
Green
See 3-4. Verification Items, (2) EEPROM information print.
3 times
Orange
EEPROM initialization
4 times
Green
Waste ink counter resetting
5 times
Orange
Proceed To the step 5), and follow the destination settings
procedures.
Destination
1 time
Orange
Japan: iP8600
2 times
Green
Other than Japan, non-support of CD-R printing (A4): iP8500
3 times
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
