Question about Onkyo TX-DS747
My unit switches between speakers A, B and neither, while warming up. Lasting anywhere from 5min-15mins until it settles. Then speakers A can be selected and it will stay there. How do I fix this?
I see that I am not only one with same issue with TX-DS747, and would be grateful if someone could post some more info about this problem.
Posted on Dec 15, 2009
I have the same issue. If you search this site for TX-DS747 and protect, I think you will find the answer.
Posted on Dec 11, 2009
Black vertical line showing on a Sony 70XBR950 TV on startup lasting about 5min.
If the problem goes away after the set has been on I'd look at back connection from the LVDS cable to the tcon board or the flat ribbon connectors going to the panel...it also could be the tcon board as well but generally they don't fix themselves as they warm up
Feb 27, 2018 | Sony Televison & Video
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
Macerator works only for 5mins every 15mins. But won't work during the 15mins.
Well it is working in a stinky environment! Just think, without it you could be hand chopping all that "stuff" up!!!
http://www.ehow.com/info_12169188_saniflo-system-work.html
Sounds like you have a sticky switch inside the macerator.
http://www.saniflo.com/products/index/show-product/lang/en/type/part/id/54
As this is a messy piece of plumbing, I'm going to recommed that you take it out of the system and take it outside in the yard, away from the house and give it a good hosing out. It is possible that some gunk has clogged up the pressure chambers vents and this is causing the float or whatever mechanism in there to be stuck on. Flush it as much as possible before you disconnect it.
Sep 04, 2012 | Saniflo SANIPRO Macerating Pump
Upright freezer quit cooling, interior fan runs, compressor runs
The coils are most certainly there probably located under your unit. Clean them thoroughly. Look under and to the very top of that space.
Jul 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Brand new long life AA batteries only lasting 15mins
Hi there.
This is a common problem with just about any digital camera out there (even my own).
After spending loads of money on top named brands and types i found that Duracell Alkaline batteries lasted just about the longest in my camera which is a Samsung S 500. Even so i would advise that you stock on them because the camera's do tend to eat the battery power.
Good luck and thanks for using FixYa!!
May 21, 2009 | Kodak EasyShare Z1275 Digital Camera
Top up tv+ digital tv stopped working.
i had same prob, tried unplugging three times
then unpluuged for 5mins
, plugged back in left it alone, ie didnt touch remote or front panel, until it settled down ~15mins, green light came on (doesn't normally)
and everthing seems ok now
May 03, 2009 | Televison & Video
RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
Jul 03, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Rt2250 rt2500 speaker static noise hum buzz until fully warmed up
It sounds like a capacitor in the power supply is just about to die. With the power disconnected have a look at the large tin can looking gizmos near the power transformer. There could be a couple of them. Leave the unit switched off for a while before going near them they could still pack a splat. Replace them with the same value and make sure they're connected the right way and it should solve your problem. Whilst in there have a good look for any other smaller capacitors which look as if they're getting rounded at the top. Replace them too. Either that or dig deep and buy a new one.
Oct 23, 2005 | RCA RT2250 System
Onkyo TX-DS747 Logo
438 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
