Question about Refrigerators
I hear the burner light as i hold in the safety valve but when i release it the burn stops immediately and the igniter comes back on. I cleaned the oraface and made sure the relationship of the thermocouple to the burn tube was ok. what gives. could it be the thermocouple
  • 952 Answers
Aha!! its a thermocouple problem, it's not generating enough voltage to keep the valve open.
Posted on Jul 04, 2009
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 02, 2014 | Kenmore Ovens
CANDY GAS OVEN - INCONSISTENT GAS FLOW- ( BRAND NEW)
First, Change your technician.
There is a part that senses the heat from the ignited gas, usually quite close to the flame on the oven burner where it first ignites. It is called a generator and it produces about 1/3 of a volt, that holds the gas valve open only while the flame is lit, as a safety device. Pressing the knob at the time of ignition bypasses this by holding the valve open, after releasing the knob then the system relies on the presence of an oven flame to hold the valve open. Check the generator at the point it enters the oven control valve, is it loose? Maybe it is faulty or the oven valve is faulty. Any real technician can identify the the problem easily.
Oct 31, 2017 | Candy Washing Machines
I have a Whirlpool Gas Range with Accu-Bake. On one of my burners the igniter comes on but the burner will not light. You can hear the clicking, but no flame. Is there something that I should clean and...
In addation to the spark do you hear th egas flowing as well? if you do hear the gas and can light it with a match/bbq lighter but it doesn't light with the spark,it could be cleaned by using a safety pin/paper clip and push through the holes where the flame burns all around the burner(s) also steel wool will clean the burner.
Gene
Aug 14, 2011 | Whirlpool Gold GW399LXU Gas Range
3 burner - front and rear ignite,middle does not. Replaced all 3 burners. Still does not light. Suggestions?
It might be an igniter problem. It might be a problem with the gas tank (either empty or not releasing the gas). It could be a problem with the control valves or even with a safety mechanism that prevents relighting the grill after multiple tries because of a possible gas build-up. Make sure the gas tank is full and releasing gas - you should be able to hear a hissing noise in the burner compartment. If you can hear the noise then you need to check the igniter and make sure you are getting a spark, and that the spark is reaching the burner. If you can't hear a noise then either the control valves are the problem or the safety mechanism is operating. You can also call Weber and they are pretty good at helping you figure out the problem.
Jul 23, 2011 | Weber Genesis Silver A Grill
Will light and remain lit 5min. 30min i dont think its thermocouple thinking something with the safety tilt
First, for those of you who might not know, "What is a flame sensor?" A flame sensor is a safety device. When your furnace's main burners ignite (light Up) the flame sensor picks up the heat from the furnace's main burning and says, "YES," and sends a signal back to the main furnace control board saying that it is OK to let the main burner stay on. Or if the main burners do not ignite, the flame sensor does not pick up the heat and says, "NO" to the main control board, Shut That Gas Valve and Main Burners Down! Thank God we have safety controls like the flame sensor. Most of the time, after turning your furnace's power off, you may clean the flame sensors with light sand cloth, emery cloth or steel wool. Reinstall the flame sensor and you are back in business! Over the years flame sensors can build up a light coating of burned-in dust and dirt. This insulates the flame sensor so that it doesn't sense the heat of the flame well enough, by cleaning it you have almost restored it to its new condition.
Seldom, but sometimes they do go out completely.
Nov 08, 2010 | Heating & Cooling
Ignitor lights up and I can smell and hear the gas, but the oven will not light
When the bake igniter becomes weak or burns out, your oven will not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Nov 13, 2009 | GE Ovens
Oven wont light
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
-- defective gas valve coils(This will be the next possible issue if the igniter is functional)
Sep 26, 2009 | Frigidaire Ovens
The gas oven will not light. gas burners light but oven does not
O-defective thermostat
O-defective selector switch
O-defective gas safety valve
O-defective gas valve coils
Sep 20, 2009 | Ovens
Rinnai burner goes out when ignition button is released
The thermocouple [s] require replacement, or in my experience try servicing the unit first. There is an injector for the main pilot and a secondary injector for the flame thrower ignition. Both of these are prone to blocking due to dust and can be enough to shut the unit down. Although usually this is thermocouple related as you are manually keeping the unit running when you hold down the button, if the tcouple is broken it wont send enough millivolts to hold the magnetic valve open when you release the button.
Cheers
May 16, 2009 | Rinnai Heating & Cooling
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
