Question about Apple iMac G5 Desktop
Screen Changes and Comupter freezes
Our 18 month old iMac G5 has recently stopped working properly. After a short period of use (5 - 20 minutes) the display morphs into what looks like a hazy bluish overlay of a series of vertical and horizontal lines/boxes. It also freezes. HELP! Any ideas?
  • 4 Answers
Re: Screen Changes and Comupter freezes
If you are lucky you may qualify for the extended repair program from Apple.
Read about it here:
If not you may want to join the others who don't have AppleCare and are not too happy.
Less sympathy found here:
If enough people complain Apple may extend the repair to more serial numbers as has happened in the past. Macs are generally excellent machines and well worth the money but problems can arise in manufacturing considering the widespread sources computer companies must use to compile their product.
Good luck, let us know what happens.
Posted on Nov 19, 2007
  • 382 Answers
It may be possible that the power supply, display and or logicbpard may be having issues. Apple recommends resetting the pram and nvram. If issue persists reset SMU. YOur machine is 6 months outside of the original warranty, but if you purchased the 3 year extension plan, you may want to take action on it.
Keep me posted.
Posted on Nov 11, 2007
0 characters
3 Points
Lines on imac g5 screen
For more help follow the Apple iMac g5 line on screen discussion over here
and if isn't helpful then take some guidance over it Mac Tech Support .
Apr 16, 2014 | Apple iMac G5 Desktop
Android File Transfer
Hi Kim,
Yikes, an Android phone on an iMac G5...
It is probably an upgrade or an update that was not compatible with the G5 Processor... That machine is going on 10 years old now...
Try connecting it to another computer, a friends or at work, to see of it connects properly... if so, it's end of the line for G5's ;-(
May 27, 2013 | Apple iMac G5 Desktop
Frozen page on imac
Hi Mike,
iMac G5, more than 10 years old now....
sometimes, the new applications on the old Macs just don't work well...
Are you able to get out and start again?
DOes it freez every time?
Have you made sure your up to date, software update...
Honestly, it's time for a new mac...
You can import all your data to the new Mac and it will make your head spin to see the difference in preformace and capacity.
Apr 13, 2013 | Apple iMac G5 Desktop
About 6 months ago there were 2 colored vertical lines on my desktop screen. I've been getting more lines every 2 or 3 weeks and now have a total of 18. The nearest Apple store said they can fix it no...
It should not affect the data on the hard drive but with all repairs such as this it always worth making sure you have your hard drive backed up. I had a similar problem with a imac a couple of years ago and the hard drive was fine when it came back. Hope this helps.
Nov 14, 2010 | Apple iMac G5 Desktop
My 21" mid 2007 imac periodically freezes, the
Try booting it into single-user mode holding down Command(Apple) and S buttons when powering up. Then in terminal console, use chkdsk -fy. Use it and use it again until comes back with something like "Volume appears to be OK". Then use command: mount -uw / and then type reboot and try booting normally.
If it does not fix your problem, it's most likely a hardware issue (logic board / graphics card), and you should take it to an Apple Authorized Service Provider.
Nov 08, 2010 | Apple 24" iMac Desktop
A fine vertical blue line running through imac screen
How long is a piece of string? is the kind of question you've asked. I've a sneaking suspicion you'll get sick and tired of it before it finally goes.
Jun 03, 2010 | Apple iMac G5 Desktop
Imac G5 keeps freezing on turn on
Get out your Mac OS disc and restart your computer and get that disc into the drive. You may need to restart with the disc in, but that's ok.
Just restart again with the "C" Key pressed and the computer will launch with the OS disc, and then you can access the file menu when it finishes launching.
Choose "Disk Utitlity" from the file menu and you can repair the system files on your hard disk.
then restart without the disc in the drive.
Sep 14, 2009 | Apple iMac 24" Desktop
I have an iMac G5 2Ghz that when it start up you can only see video for a few seconds. I connected an external monitor and my iMac works fine but with its on LCD there is no video. I check the logic board...
The iMac G5 and iMac G5 (Ambient Light Sensor) computers have a video out port located on the back of the computer, which will mirror video. Video mirroring means you can see the same image that is on the iMac G5's flat-panel display on an external monitor, television, or projector.
Using the video out port, you can mirror video with a compatible VGA display using the Apple VGA Display Adapter.
You can also use the video mirroring feature with a television or projector that has S-video or composite video connectors when you use the Apple Video Adapter.
Both the Apple VGA Display Adapter (M8639G/A) and the Apple Video Adapter (M9109G/A) are available separately, and are needed if you want to use your iMac with a VGA monitor cable, S-video cable, or composite video cable.
The video mirroring feature is "plug and play". Simply connect a VGA display, television, or projector to the appropriate adapter (see above), then connect the adapter to the video out port located on the back of the computer.
When you connect the adapter to the computer, the screen may refresh momentarily as the computer prepares itself for the new video output. The computer tries to match the resolution of the built-in and external display. If there is no match, the computer changes both screen resolutions and may black out areas on the built-in display in order to match the capabilities of the external display.
Important: To ensure that your iMac G5 automatically detects the external display or projector, be sure you plug the adapter into the external display or projector before you plug it into the iMac G5.
You can switch resolutions and frequencies for both the iMac G5 flat-panel display and the external display, television, or projector using Displays preferences.
Want to watch a DVD movie disc on a television that's connected to your iMac G5? Select a 720 x 480 NTSC (in the United States) or 720 x 576 PAL (in Europe and other regions) resolution in Displays preferences.
Tip: Because of the display limitations of most televisions, the images displayed on a television screen are usually not as high quality as those on the built-in display or an external monitor.
Good Luck
Aug 21, 2009 | Apple iMac G5 Desktop
IMac clarification
Okay, you probably need a new power supply, this unit had many power supply and logic board problems.  300.00 is a lot for a power supply, 120.00 is the usual cost plus 50.00 labour, and that is canadian dollars, it should be much cheaper if you are in the U.S.
Nov 06, 2008 | Mac Desktops
Apple iMac G5 Desktop Logo
571 people viewed this question
Top Apple Mac Desktops Experts
 Mike M
Mike M
Chris Hunt
Lawrence Oravetz
Are you an Apple Mac Desktop Expert? Answer questions, earn points and help others
