Question about Comet BXD2527 Pressure Washer Pump
No high power water pressure coming out of my model #580.768030 pressure washer. The same pressure comes out when the pump is turned off.
  • 40 Answers
You should dismantle and clean the manifold from the pump , it is sticking. Common
Posted on Jul 03, 2009
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Tip
Winterizing your Pressure Washer
Once again it's that time of year to get your pressure washer prepared for the cold months ahead. Proper winterization will protect your pump from the freezing of excess water in the pump over the winter. There are many ways to winterize your pump; we like to classify it as the good, better and best.<br /> <br /> Good: (Gasoline powered) Leaving your machine in the off position with the high pressure hose disconnected pull the recoil rope 4 to 5 times or until you don't see any more water coming out of the high pressure end of the pump. (Electric powered) Disconnect your high pressure hose, turn the machine on for 5 to 10 seconds or until you don't see any more water coming from the high pressure end of the pump.<br /> Better: If you have a air compressor around the house, hook the air line to the garden hose end of the pump and blow the water out until you don't see any more water coming out of the high pressure end of the pump.<br /> Best: Purchase Karcher's Pump Guard, follow the simple directions that come with the product. This product is specially formulated to keep your pump from freezing, corrosion, premature wear, adds lubricant to the valves and seals to prevent sticking in the spring. You can usually get 2 or 3 uses from one bottle of Karcher's Pump Guard. <br /> <br /> <a href="http://www.wmpcs.com/blog/?p=63">Visit this link to read more</a>
on Nov 01, 2010 | Garden
Throttle linkage is loose and when started water does not come out the nozzle after BEING BLED OF AIR
The unloader on your pump is bad...this is causing both problems. Find your pump model # ...probably an AR pump ...they fit the Honda GC engines well and go to this site Pressure washer parts catalog quick links Pressure Washers High Pressure... they can guide you to the correct unloader... Good luck
Jan 19, 2014 | Powerboss 020309 3000 psi 2.5...
I have a 2600 Troy bilt pressure washer.When I start the pressure washer,no water comes out the nozzle and the nozzle is not clogged either.I took the nozzle/gun off and there still was'nt any wat
If when you take the High Pressure water hose off the pressure washer pump no water will come out they you may simple have the bypass valve stuck. You may need to just remove the outlet fitting and clean the bypass valve.
It would be helpful to know the model number of the pressure washer or the pump.
Mar 29, 2012 | Garden
Dayton pressure washer motor runs no water coming out of wand
Not sure what model you have but take the high pressure hose off the pump and see if water in coming through the pump.
If water will not come through the pump then check the outlet port of the pump.
If water is coming out of the pump but wont come out the end of the want then you may have a clogged nozzle in the end of your wand.
Oct 23, 2011 | Heating & Cooling
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
Not getting any pressure at nozzle.
Can anyone Solve this? My simoniz S2500 gas powered pressure washer has low pressure coming right from the outlet. It used to be high pressure until now.. I think it has something to do with the pump and if so, is there anything I can do to repair this problem? The screen is good; water comes out of the hose good, wand is ok......Just that lower pressure is at the wand even at high settings....It comes in a form of a spray in both modes......
May 17, 2009 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
There is no power when you use the sprayer Karcher K2.89
Depends on the model, but it is probably the pump, Most Karchers do not use expensive pumps. Also, if the end of your hose is off, you won't get much pressure either as it takes a restriction in the end of the hose to increase the pressure. I have commercial pressure washing business & occasionally have an hose end come off, pump problem or high pressure switch problem, but all this stuff can be fixed. Hope this helps you, Rick
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Comet BXD2527 Pressure Washer Pump Logo
475 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
