Whirlpool washing machine, works when turn manually, but not auto
The washing maching works if you turn it to each cycle manually, but will not turn thru all the cycles on its own automatically. Is this just a simple part on knob to fix or what?
  • 40 Answers
That would be your timer. Yes, it would have to be replaced and it isn't cheap depending on the year and if it is digital or not.
Posted on Jul 03, 2009
Rinse Light flashes on Miele W829 novotronic
Remove all the load and try to move the drum manually clockwise and anti clockwise. If you notice any friction check the motor separately and the agitator assembly separately.
It could be due to alignment shift causing a wobbly motion or a failure of the bearings.
Check these links:
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlForreplacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html.
Jul 29, 2012 | Whirlpool Washing Machines
THE WASHING MACHING FILLS WITH WATER, GOES THROUGH
Most Likely it's the timer. try to move it by hand to the net cycle. If that doesn't work it's the contacts on the inside fouling up.
Sep 06, 2009 | Whirlpool Washing Machines
The agitor is locked
Try unpluging the maching then start the wash from the the start. Here is the manual.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/8566930.pdf
Aug 12, 2009 | Whirlpool Washing Machines
Whirlpool washer will not drain
Well i think you should be looking in the filter? Or in the pump. These are the only thiongs that will stop it from draining or spinning! The machine will not spin if it has water in it. It will go into spin inhibit to protect the machine. Check for lost items and then look at pump/filter if nothing then replace the pump then you will be ok.
Jan 02, 2009 | Washing Machines
Tub spins too fast on all cylces
Just wondering: did the technician also replace the motor control unit? Or is that the 'spin unit' that you mentioned?
See pages 4-7 and 5-4 in the repair manual.
http://adcxns1.whirlpool.com/Service...0Job%20Aid.pdf
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
