Question about Whirlpool 24 in. DU948PWPQ Built-in Dishwasher
Will not drain at the end of the rinse cycle. I can push the Cancel/Drain button twice and it will then drain out, but automatically during the selected cycle.
  • 40 Answers
That is a common problem with the board. Expensive.
Posted on Jul 03, 2009
I have a SHU5305us/u12 and my front door lettering got erase. anyone have a picture or a manual that tells me what each button means.
Cycle Interruption
As a safety feature the dishwasher will automatically turn itself off whenever the door is opened. However, if the door is opened quickly while in a wash or rinse cycle some water may splash out of the dishwasher. For this reason it is recommended that the machine always be switched off before opening the door.
To Interrupt a Cycle
1. Press the on/off button to stop operation.
2. Wait at least 10 seconds (or until the water noises stop) before opening the door.
To Resume a Cycle
1. SHU/SHI models, close the door and press the on/off button.
2. SHV models, push the on/off button and close the door.
Changing a Cycle
For Bosch dishwasher models SHI 6800 and 4320, SHU 5300, 5310 and 6800 press the program button of the desired cycle TWICE. For all other Bosch dishwasher models, press the program button of the desired cycle ONCE. The chosen cycle button (or the light above it) becomes illuminated, showing that it has been selected.
* SHU 3030 and SHU 3130 models do not have program lights.
Cancelling a Cycle
Each control panel shows which buttons to simultaneously push to cancel a cycle. Refer to your dishwasher to find the cancel drain buttons on your particular model.
1. Press the indicated buttons at the same time and hold for approximately 3 seconds.
2. When the drain pump noises stop and the LED display or clean light indicate that the end of the cycle has been reached, the dish
washer is reset.
3. Press the on/off button to turn the dishwasher off.
4. The dishwasher is now ready to run a selected cycle. Add more detergent if necessary.
Dado
Oct 05, 2015 | Bosch Dishwashers
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    What does it mean if the washer is not draining and has a flashing f where the time shows?
    I have the manual for this machine. Under "Code 21" it says the following:
    "F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
    For "SUDS" code, the following:
    "SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
    Here is some more information that may help you as well:
    "F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
    I hope this is of some help to you, Please rate and comment, Thank You
    Joe
    Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
    F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
    Joe
    Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
    My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
    What does the Sd code mean?
    This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
    Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
    Use only HE High Efficiency detergent for BravosTM washers.
    Is "Sd" displayed and the wash cycle dial is flashing?
    This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
    Is "Sd" displayed and the wash cycle dial is not flashing?
    If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
    Is the drain hose kinked or clogged?
    Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
    To remove the error display, press Power/Cancel or Pause/Cancel once.
    If Power/Cancel or Pause/Cancel does not work:
    1. Unplug the washer or disconnect the power for one minute.
    2. Plug in the washer or reconnect the power.
    3. Re-select the cycle and press Start/Pause.
    NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
    Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
    Error code HF
    Washer displaying code message and tone sounds S "HF" 0Nater Inlet Problem--no water or insufficient water supply) Select PAUSE/CANCEL twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Are water faucets completely turned on? Are screens at inlet hose connection to washer clogged? Are water inlet hoses kinked? Are water inlet hoses frozen? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service. "F02" (Drain Problem) Select PAUSE/CANCEL twice to cancel the cycle, Unplug washer or disconnect power. Cl_eck the following: Is the drain hose kinked? ts the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96 in. (2.4 m) above the floor? = "SUD" (Suds Routine) When excessive suds are detected, a suds routine
    Sep 23, 2010 | Kenmore Elite 45986 Front Load Washer
    Quick Rinse light was flashing at end of cycle. Opened and closed door and pushed Start. Quick Rinse and Cancel/Drain light are now flashing and machine won't start. Turned off power supply (30 seconds) /...
    Ok try this, open the door and then hit these buttons in the following combination. HI TEMP - DRY - HI TEMP - DRY...then close door and press cancel...then wait for the pump to shut down. you should be able to run a cycle after this...If this fails to fix the problem give me the make and model # of the dishwasher, this can normally be found just inside the door.
    Jun 22, 2009 | Dishwashers
    Whirlpool Dishwasher won't drain during normal cycle
    As you say a clogged line or valve does not make sense.
    Try running it without the heated drying and see if it empties or if the cancel button will work then.
    The dishes should air dry quickly if you empty it and open the door.
    It could be a defective thermostat allowing it to get too hot during the heat cycle
    May 18, 2009 | Dishwashers
    Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
    Hi Claire,
    Are you using rinse aid?
    that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
    Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
    F 02 ERROR
    Try cycling the washer a few times without a very small load of clothes and no detergent. I assume that you are and have beenm using only HE type detergent and I suggest you try using about 1/2 to 1/3 the amount called for until your system is purged of any and all remaining detergent in the lines. Here are the manufacturers reccommendations to address your problem..
    “SUD” (Suds Routine)
    assures proper rinsing of your garments. “SUD” is displayed
    during rinsing and at the end of the cycle to inform you that
    detergents.
    Hope this helps you..
    “F02” (Drain Problem)
    Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool 24 in. DU948PWPQ Built-in Dishwasher Logo
    191 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
