Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Vacuum roller will not spin. Reset button does not workl
My Vacuum is a Model 116.35922500, I just bought a few monthes ago. Just discovered the the Roller/Agitator will not rotate when the system is turned on. Ilve tried reseting the button on the top of the body, but no change.
Is this a common thing for this system and is this under warranty?
The warranty should cover you for a year unless something you inadvertently sucked up caused a jam, whihc you may be able to determine or fix yourself. See if the agitator is easy to turn - if not, something is probably jamming it; if it turns in one direction, but not the other, something may be wrapped around it. If it turns easily, it's possible the motor either died early due to a defect or a broken wire.
Posted on Aug 01, 2009
J BOUGHT A TROTEC TTK170S ONE MONTH AGO IT STOPED WORKING ON FRIDAY LAST AND HAS NOT WORKLED SINCE
hi it may be that started leaking inside him so his security system blocked functions .in that case a lamp would be blinking on his front panel. also,security system reacts on bad connect hose with liquid bawl (it may fell of). if this doesen`t help try to leave him for few more days on a dry ,worm place and them star him again. if still doesent work then he needs a repair service.
these are not only solutions.there is always several solutions just you have to give more informations about malfunction . hope i helped,good luck!
Feb 27, 2011 | Vacuums
I have a model 116.35922 beltless drive vacuum. The agitator brush will not turn with the vacuum running and the handle down. The brush turns by hand and the reset button has not popped. Ther is nothing...
I just had the same problem. The roller will not turn if the unit is overheated. I discovered that my bag was too full. I changed the bag then the roller started turning again. I don't know if this is true cause and effect, but it couldn't hurt to try.
Aug 23, 2009 | Kenmore Vacuums
My roller do not spin
There is also a circuit protector which trips if something gets caught in the roller, so that might be the problem. There is a very small red button on the right side at the bottom of the vacuum (IT'S VERY TINY), and you just push that in and it will reset the circuit.
Aug 22, 2009 | Kenmore 31913 Progressive Direct Drive...
Vacuum belts smokes and needs to be replaced 3x's in 6 months is tis normal or did I get a lemon
brush roller berings may be faulty making the brush stick and motor shaft spins against belt causing melting. remove brush roller, clean out end berings and see if ends spin freely or if they stick. if they stick, you might need to replace brush roller.
Jul 30, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Feb 25, 2009 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a hoover windtunnel upright vacuum bought it a few months ago and now the brush spinning stopped working.
You probably have a broken belt, or the belt came off. The Self Propel Windtunnel has an issue with the pulley that tightens the V-belt in place getting stuck and needs to be taken apart and released, but most likely its just the belt. They should be replaced every 6 months or so, and the part number is usually on the serial tag of the machine.
Nov 22, 2008 | Hoover Vacuums
Vacuum keeps burning up belts
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=565438
Generic problem for all Vacuums
Posted by campoclan on May 02, 2008
Vacuum keeps burning up belts Comment by campoclan, posted on May 02, 2008
I have a Kirby Sentra and have had problems since I bought it a few years ago with burning up belts. I go through at least two a month. What is wrong with it? I keep the roller clean each time I vacuum.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Some Kirby vacuum in the brushroll have bushings and some have bearings and the bushing bind up and do not spin properly and I suggest to replace your brushroll with a genuine Kirby belts and brushroll of which would work the best for you performance wise. A suggested belt change depending on carpet can be every 3 to 4 months or 4 to 6 months and the brushroll when needed, some carpets are ******* the belts and they do require change more frequently. The rest should be fine. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Not working
If only 2 months old, take it for repair as it is under warranty.
Mar 28, 2008 | Dyson DC18 all floors Bagless Upright...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
643 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
