Question about Dishwashers
Broken vent in dishwasher door . Is it replaceable?Where do I find replacement part?
  • 40 Answers
Call your local used appliance man, they do repairs and sales of various models. Chances are they may have one and give it to you, if you promise to give them your future business while accepting their business card.
Posted on Jul 03, 2009
Message "er" and "uo" on front panel and slight bumping noise
The UO code on most Frigidaire dishwashers means that the vent at the back of the dishwasher is open (or at least the sensor is claiming it is open). Since this vent should be closed except during the drying cycle, the unit will not start. This avoids having the washer spray water into your cabinet during the wash cycle.
The vent sensor is an optical sensor that is inside the vent assembly. So there are a few places that could fail causing the error. First check the wiring and the connectors for the wires between the vent and the CCU (main control board). If there are any broken wires or corrosion the message may not be reaching the control board. Replace any faulty wiring. If the wiring is fine, try replacing the vent assembly. On some Frigidaire models, the wiring and the vent assembly need to be replaced at the same time. If that doesn't solve the problem then the control board needs to be replaced.
Please note: when I look at the parts for the FDB1050REC0, I found a static dryer vent, http://www.appliancepartspros.com/frigidaire-static-dry-vent-154433001-ap3214620.html . Please make sure that you are buying the parts for the correct model dishwasher.
I hope this helps.
Dec 17, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Dtergent dispencer does not open
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Enter your model number to see parts for your dishwasher.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
God bless you . see the photo attached.401f2962-5d22-48f3-89be-c1db11d8eabe.jpg
May 23, 2013 | Hotpoint-Ariston FDD914 24 in. Built-in...
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Dishwasher Leaks
Find a new repair person
Apr 07, 2017 | LG LDF7932ST Dishwasher
The 2 metal "clips" that secure the dishwasher to
door gasket possibly bad or another leak. Stop using dishwasher until repaired or you're likely to ruin your floor. I just had this problem before we found a leak and now we may have to replace the kitchen flooring.
Order new clips or the dishwasher could fall out onto the floor or even onto your foot.
Nov 16, 2017 | LG LDF6920ST Stainless Steel 24 in....
Lg lds5811 leaking in front at bottom left of door. cleaned gasket and door, still leaking. any ideas, thanks
if its leaking down the vent out the bottom of the door when it runs.you need to replace the vent fan ***.the gasket on the vent door is bad.
Feb 24, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LG Dishwasher LDS5811bb. Water is leaking out
The dishwasher may not be levle side to side and front to back.
Se the installation instructions or go www.lgusa.com
they may have the instructions on line.
This will cause leakage at the door.
If the leak is @ the bottom left it may be from the drying vent assembly.
The vent would need to be replaced with an updated vent assy.
Jan 16, 2010 | LG Dishwashers
Vented vs. non-vented dispenser unit
If you cannot get a non-vented unit, just buy the vent fitting that fits onto the dispenser unit....it runs accross the door panel and down the door to the gutter in the bottom of the door. There should be no problem using the unit "as-is", but if you see small amounts of water dripping from below the outer door panel, get the vent tube. It should be inexpensive. Oshie
Jun 17, 2007 | Bosch SHU5316UC Dishwasher
Broken door handle Indesit dishwasher DG 6100
I agree read "broken door catch" solution and be particularly careful in respect of the edges of the stailess steel panels - some of the edges are hidden and they are very sharp.
Jan 29, 2007 | Indesit 24 in. D61 Free-standing...
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
