I have a colman a/c rooftop for my esprie travel trailer I hooked up digital thermostate I got the heat side to work but ac doesnt. the termanials on thermostate are Y W G rh rc
    Brigadier General:
  • 8,619 Answers
Hi
Please connect the wiring as shown in the following manual--
Coleman A/C rooftop wiring information
After wiring as described in the service manual, you would be able to use both your heater and A/c.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on Jul 04, 2009
Dometic rooftop ac and heat pumps not working ona 2010 heartland 5th wheel trailer will not work
check your d.c. fuses and circuit brreakers. need a full 12 volts d.c. to operate.
Feb 13, 2014 | Dometic Rooftop RV Air Conditioner
TRYING TO FIND THE RIGHT DUCTED AIRCONDITIONER COLMAN. FOR 1995 TRAILER
The upper unit doesn't matter ( the actual ac unit on roof ) it's the lower control unit (inside at ceiling) that you need to change to use either ducted or non-ducted system. Any RV dealer can supply that, probably have it on the shelf. Just make sure you write down the model number and serial number, off the bottom of the upper unit, so they can match lower unit to it, for ducted system.
Apr 14, 2010 | Dometic Rooftop RV Air Conditioner
DOES MY COLEMAN ROOTOP HAVE FILTER ON THE OUTSIDE (ROOFTOP)
You dont have a filter on top unit but you need to have your fan impeller and condensing coil clean regularly about once a year and more when your on dusty area.
Aug 21, 2009 | Dometic Rooftop RV Air Conditioner
Put new digital thermostate in trailer furnace works a/c doesnt. when i hook up all wires with jumper on hunter thermostate the blower for ac comes on and stays on
Different manufacturers may use different color wiring so you will need to do some tracing on your own. typically, W=heat, Y=cool, G=fan, RC+RH=24v. The jumper should typically go from RC to RH. This is just general information and may not solve your specific problem. It is difficult for one to diagnose without seeing it first hand.
Jul 06, 2009 | Heating & Cooling
I have a travel trailer with a roof top a/c colman mach111 and I hooked up a thermostate digital. The heat works but cant get a/c to come on. the termanials on hunter thermostate are G W Y RC RH
OK, the wiring that you should have in your RV is as follows: Red White Blue Yellow Green Gray.
This Thermostat will not work on this Air conditioner because the tstat you are installing is a 24V thermostat. The connections are as follows G = Fan, W = White, Y = Cooling, RC = 24V Cool, RH = 24V. The only thing that I can think to do is hook it up like so.
On the G Terminal, Hook up the Green wire from the wall. On W, hook up the White wire, Y, hook up the yellow wire. RC = run a jumper from the RH terminal, RH = hook up the red wire. If this doesn't work then you will have to go back with the coleman thermostat.
Jul 03, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
