Question about Whirlpool GHW9150 Front Load Washer
Whirlpool duet water leak
My duet washer has been leaking water after a wash is complete from the rubber seal through the outlet at the top of the rubber ring which faces you when you open the door. I have been finding either a small puddle inside the machine if I close the door after emptying it and last night I had a gush of water from the outlet spill onto the floor. The machine works great and this only occurs after the cycle is complete. What is wrong ?
  • 3 more comments
  • Anonymous Nov 15, 2007
    I have the very same problem, I have tried cutting my water supply off, and one of my supply valves will not close fully and the washer will still pull what little water is coming through the valve into the washer. I did not realize it was doing it and I came home from work with a flooded utility room twice. Then after running clothes or whatever through a cycle it does finally quit and will be just fine for maybe a week to ten days, then for no reason it starts again. I have now made it a routine check every morning before going to work to check the washer to make sure it is not leaking the water from the rubber boot on the upper left side. I have even put my dirty towels inside just in case, thinking they may absorb the majority of the water should it start on its own while I'm away. Since I am not alone in this I think this may be a machine defect. Possibly something to do with the computer or whatever brain this machine has. I do love my washer but this must stop, I can't and won't allow this washer to dictate how I spend my time.
  • elmosisu Feb 12, 2008
    Same problem here! After a wash cycle, it will slowly fill with water. I end up having to manually turn off the water supply. Is there any other option besides calling a service company? Can I replace a fill valve? I am a handy person!
  • March 2008 Mar 27, 2008
    Same problem. Cycle finished. Everything fine.
    Couple of days later, surprise! H2O filling the tub. Sounds like a check valve issue to me.
    I wonder if too-high water pressure blows out a check-valve...
  • ejp1 Jun 25, 2008
    Have the same exact problem. Wash cycle is finished and sometime later, find water on the inside of the washer. Had to run the spinner cycle to get rid of it. Couple of times flooded out onto the floor. This last time, the door was shut, and it was filled halfway up inside with water. Can't get the machine to do any cycle. Will have to call out repairman. No solution or cause known yet. Does sound like a defect...
  • Anonymous Aug 19, 2008
    Between cycles (i.e. the washer is not running) water will drip from the spout inside the drum. Slow drip but it will put out a couple gallons overnight. I tapped on the water inlet valve with a screwdriver and the dripping stopped after a few minutes. Unit is 18 months old.
    Sounds to me that for whatever reason, the valve is not closing completely and probably requires replacement.
  • 1,294 Answers
Open your wall faucet to full pressure to stop the drip. If this does not work simply change the inlet valve of the machine which is at the top, where the water enters the machine. You can do it yourself. And rate me plz if helped.
Try these sites for spares:
Posted on Mar 31, 2009
  • prem mathew Mar 31, 2009
    Unplug washer, turn off water supply and remove hoses from the back of the washer.
    2. Remove the top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
    3. The water inlet valve will be located at the left rear of the washer
    4. Remove the dispenser hose, electrical connections and mounting screws and the valve is removed.
    5. Install new valve by following steps in reverse order. Note: When reinstalling top panel, make sure you lay panel on top of washer, leaving a couple of inches of room from the front panel. Then slide panel towards you (front of washer) so that the top panel slides into the mounting clips.
  • prem mathew Apr 09, 2009
    Servicing the valve.
    The cold water valve is probably stuck open. It should open only when there is voltage across the valve. It could just be clogged inside. If you can remove it, you might be be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassemble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
  • 5,911 Answers
This problem is commonly caused by one of the door bellow seals coming loose, or if the bellow has a small rip or tear. The following link will provide you with guidance on how to disassemble and/or replace if necessary: determine if you have a bellow seal leak, remove the lower panel under the door and observe the area under the bellow in the front where the drain pump is. If the bellow is leaking, it is common for the front counterweight (looks like a concrete block) to become wet or damp. Inspect the area under the rubber folds of the bellow around the perimeter of the door for crack, rips, or tears. It is common for the rubber to wear out due to age and require replacement. If no holes are found, make sure the dispenser tube that enters the bellow from the left hand side is inserted properly through the rubber. Sometimes, the tube is not inserted all the way and will cause water to drip behind the bellow during the wash and rinse cycles. Also, check the rear bellow clamp that holds the rear portion of the bellow to the front of the wash tub. If this clamp becomes loose, it can leak and/or cause the bellow to become dislodged. There is a a 7mm nut that you can tighten behind the front panel. Do not overtighten, as this can damage the clamp or wash tub.
If there is no standing water in the wash tub, this is NOT caused by the water inlet valve. Replacement bellows can be purchased at,, or All three sites offer competitive pricing, so shop around for the best price. If you still have questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on Apr 01, 2009
Call service
Posted on Jan 18, 2008
My washing machine is leaking
Through the door? Where is it coming from?
If door, check the rubber seals are ok and not torn, broken or perished.
If elsewhere, could be a break in the drum or a water pipe loose
Oct 14, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Broken ceil on whirlpool duet front load leaks water from rubber part
You need to get a new seal. You can probably change this yourself. There is a wire clamp holding it in place that you will have to remove before getting the old seal off and installing the new seal. Finally, you will have to replace the clamp.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from front of machine
dealng with a leak of this nature, it could be anything from a tear in the door boot (rubber peice between door and tub), a pin hole in the water pump or hoses, or a bad tub seal. Ideally you need to take the top off of the machine and run it to determine where exactly the water is coming from. One other thing to check, if you are using a detergent that suds up too much, a front load washing machine will leak around the door seal... they are designed for non-sudsing detergent.
Oct 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out of the bottom part of the washer door.
If your Whirlpool FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 10, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool duet washer leaking water
If the washer is leaking around the door area, more than likely the bellow (rubber seal) is ripped or torn. If you pull back the rubber folds in the bellow and inspect, you may find a rip or tear causing your leak.
Another cause can be the rear bellow clamp (clamp that is affixed to the front of the wash tub) can come loose causing a leak between the bellow and tub. All you may have to do is tighten the clamp if this is the case.
The dispenser tube on the left hand side of the door, if not seated through the rubber correctly, can also leak during the fill or rinse cycles. The tube should be inserted through the rubber in the bellow to the flange on the tube. If not, water can fill behind the rubber and drip into the bottom washer casing.
The following link explains how to access and/or replace the the door bellow on a Whirpool Duet:,, and carry the bellow. All these sites offer competitive pricing, so shop all of them for the best deal.
If you have any questions, or require addtional assistance, please let me know. I hope this helps you. NOTE: The bellow can also become mishapened over time after frequent use. This can also cause leaks around the door. Look to make sure the bellow is sealing around the door glass. If not, it should also be repalced.
Jul 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking on the floor while filling
Open the back of the washer. Start the fill cycle and observe where the water is leaking from. You are not going to get a full view of the entire tub by only opening the lower front access.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaks from whirlpool front loading washer when washing heavier loads
Check your rubber seal in the washer by the door and make sure your getting a good seal. Part of the seal has probably pulled loose.
Jan 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Water
check your rubber bellow you might have had something go threw it.
Jun 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
3,375 people viewed this question
Dan Webster
Dan Webster
Sal De
