Question about Huffy Disney Princess 16 in. Girls Bicycle
The instructions are not helpful and we are having problems getting on the front tire. Please help.
  • 40 Answers
Install the tire b4 you install the brake assembly, You slide the tire in then make sure the safety washers are installed with the hooks in the holes. This prevents the tire from coming off should the lock nuts back off. Tighten but don't over tighten , a quarter turn passed snug is always a good rule without a torque wrench
Posted on Jul 03, 2009
Front end tires stick out on my 4x4
Good day.
The easy to solve this is to go to a tire shop and get a set of new rims that fit.
Jan 21, 2014 | 2004 Cadillac Escalade
Tire pressure light comes on when tires are okay. Can I reset something myself so it doesn't?
You are right, the pressure sensors can be affected by temperature. If its below 10 Degrees there is a chance they will malfunction, I had a similar problem on my Jeep Wrangler and it required a heated garage for an immediate rectification. Alternatively, some tire shops have a computer which can communicate with the tire pressure sensors and reset the sensors once they determine that the correct air pressure has been applied to the tire.
Oct 20, 2012 | Cars & Trucks
Flat right reat tire. Cant get a jack under to lift tire off ground to take it off. Can't lift front enough to get block under that might raise rear after lowering front. How's it supposed to come...
Hello there, the Toro 52" 27hp z master has an Exclusive Toro Z Stand on 27 hp (20.1 kw) models provides an on-board tool to simply elevate the front end of the machine and provide access to the underside of the deck.this Z stand gives access to the underside of the unit to enable you insert a jack under to change the rear tire.rockmeister_15.jpg
Here is a link to help you download the service manual, operator manual, parts catalog and setup instructions. These give more insight as regards getting the tire changed.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 10, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
I own a 2006 pontiac torrent...there is a rough vibration that feels like it is coming from the front end...had new brakes put on and the problem still exist
If the vibration is always there and it gets worse the faster you go then you have bad tire or tires on the front.
May 24, 2011 | 2006 Pontiac Torrent
95 plymouth voyger 3,8 engine vibrates under heavy accelaratioin replaced front cxels with reman then new .on help . one tire pressure to high brought pressure to spec 30 lbs . a little help. noticed toe...
jack up the car and check each front tire for movement up and down and side to side. up and down is a ball joint.. side to side is a tie rod end.
also remove each tire and roll it down the driveway and see how smooth it rolls. it could very well be a belt has slipped in the tire. replace it.
Robert
Jan 06, 2009 | 1995 Plymouth Voyager
Rear wheel alignment
first of all firestone are rip off artist. you got suckered. next there are struts on the back and yes you should align them however it has more to do with how the tire wears than a steering issue. with only 12,000 miles I seriously doubt there would have been a problem. my solution would have been if one of the front tires was bad i would have replaced it then took the 2 back tires and put them on front and the new tire and other front tire on the back and no alignment would have been needed unless your girlfriend would have complained about it tracking one way or the other. feel free to click on my user tab anytime you need help.... please rate this.........thanks
Sep 24, 2008 | 2001 Buick Century
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Mar 30, 2007 | Baby Trend Expedition LE Jogger
Huffy Disney Princess 16 in. Girls Bicycle Logo
326 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
