Question about Brother MFC 420CN All-In-One InkJet Printer
Why wont my machine feed paper to print
I tried shaking it upside down. did not help.
SOURCE:
  • 320 Answers
SOURCE: Brother MFC 8440 Automatic Feed Malfunction
you need to reset it from the printer setup menu
Posted on Jan 14, 2009
Ajkill
  • 2035 Answers
SOURCE: brother laser printer wont print
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Posted on Feb 09, 2009
SOURCE: no paper feed (brother MCF-440CN)
Had a similar problem with the MFC-885cw. Turns out that , if you have a photo paper tray installed which sits just above the main tray, you need to puill it all the way back towards you otherwise it blocks the paper feed. Not the best design feature I've ever seen.
Posted on Apr 12, 2009
  • 64 Answers
SOURCE: I got a Paper Jam message while trying to print on
First off, NEVER EVER turn a componant upside down and shake it. Second, open the printer up and search for any additional paper. A lot of time a paper jam isn't just one sheet, especially if you have a faster printer. I would also try using some rubber rejuvinator on the printer so that it picks the paper up better so it goes through the printing cycle better.
Posted on Jul 17, 2009
  • 18 Answers
SOURCE: The MFC 640CW still reports a paper jam tho I have
sounds like there is a piece of paper somewhere that you can't see it and in there snug. you may want to check again & use a flashlight if you have one available, this will help . i know it's hard to see up in there ..
Posted on Mar 12, 2010
On epson stylus photo 1410 the paper feed does not work. how to fix?
The most common problem is a foreign object falling into the rear paper tray. Remove all the paper from the tray and unplug the machine. Turn it upside down and give it a good shake followed by a couple of healthy whacks on the base. See what falls out. If nothing falls out tip the machine (still upside down) vertically from side to side and listen carefully for anything rattling inside. If you hear nothing, put it all back together and try a test print. If the paper still jams or does not feed, see which side appears to be blocked and slide a flexible plastic strip along the back of the feed roller until you find an obstruction and remove it.
Oct 04, 2018 | Epson Office Equipment & Supplies
Will not feed paper
have you made sure there is nothing inside the printer where you put the paper in at ? the smallest thing in there could keep the paper from feeding through, you may have to turn the printer upside down and shake it a bit,, carefully.. then try to feed the paper again.. ( I am assuming it is a printer and not a fax machine )
Mar 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper doesn't feed
Hi, The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Feb 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
My canon mp220 printer is not feeding paper through and there is no paper jams
try turning your printers upside down as it may have something stuck inside it!!! i had a crayon inside mine which caused the same problems as you.
Sep 16, 2008 | Office Equipment & Supplies
Paper Jam
clean the paper feeder gears. with some rough material.it will work properly.
Aug 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Epson DX6000 paper jam problem.
Shake the printer and turn it upside down.....Be carefull in doing so...
Apr 09, 2008 | Lexmark All-in-One Printer with PictBridge
Paper jam
Don't know if it's the same problem i had but its maybe worth a try. Mine is a Canon MP160 but again its maybe worth a try.
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Feb 28, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
Feb 03, 2008 | Canon MX300 Office All-In-One Printer
MP470, Paper jam on one side
There is something jammed in there....shake it upside down first.....if nothing then revese feed a paper through it manually......take left side off hold paper in front and roll wheel on the left side so the paper feeds back into the machine,,,,,,open top to see in there and when paper feeds under white rollers make sure it dosent jam where wite rollers are about an inch from the right there is a small rectangle hole with a black plastic piece in there pry it up carfullywith a paper clip and feed paper with the wheel under it at that point the paper push out a bobby pin into my back tray,,,,, now everything works great.......keep checking i didn't believe something was there either but there was..... also if your paper first starts to feed and stops pull out the paper and check for a bend or crinp in it mine kept doing that and that is exactly where the pin finally came out.....
Feb 01, 2008 | Canon PIXMA MP470 All-in-One Printer
Paper Feed
Try turning the printer upside down and shaking it. Sometimes something small like a paper clip or Lego brick gets down inside and will prevent the paper from feeding.
Apr 04, 2007 | Lexmark X75 All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
ctnozil
